Page 1 of 24 1234511 ... LastLast
Results 1 to 25 of 578
Thread: Converting to a VN Calais dash
    Jun 2005
    Default Converting to a VN Calais dash
    Since this is a topic that is constantly coming up over and over again, I've decided to write up what I know about this. If your VN has a level 1 or level 2, you can convert it to a level 3 dash with a little bit of modification to your wiring loom.
    This is the calais dash. You can get them for about $80
    You will need a few things -
    - The dash $80 or so
    - The left hand switchblock with the trip computer controls. $50 from the wreckers
    - The 4th connector that plugs into the bottom of the dash
    - The plug to go into the back of the switchblock. Your original one doesnt have the right amount of wires.
    Tools
    - Philipshead screwdriver
    - Wire stripper/cutters
    - Soldering Iron
    - heat shrink/electrical tape
    Attached are the two wiring diagrams that I used when installing mine.
    1. Take out your dashboard.
    2. Remove your fuse cover panel. Find the wires that go to the 3 connectors for the dash.
    3. Find the wires that correspond to the wiring diagrams, cut them and splice the wire from the 4th connector to it.
    4. Solder the wires together, and cover with heatshrink, or just electrical tape.
    5. Remove your original switchblock.
    6. I found the easiest way to install the switchblock wiring was to take the extra wires out of the new connector, and plug them into your existing connector. Connect these new wires to wherever theyre supposed to go in the diagram.
    7. Run a long piece of wire over to the ECU behind the left passenger side kick panel. Splice that wire into the wire shown on the diagram.
    A few other things to note -
    - You can run the dash without wiring up the 4th conenctor, but you will not have an odometer, and that wouldnt be legal.
    - Do not try to use a VR/VS dash in a VN/VP
    Thats all I can remember for now, so if you have any questions, please ask them here instead of making a new thread.
    Thanks to whoever created those diagrams, Hozy, Lexx and anyone else that helped me when I installed mine.
    Attached Thumbnails Attached Thumbnails Converting to a VN Calais dash-dash-mod.gif   Converting to a VN Calais dash-my-vn-dash-wiring.jpg
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VN Exec to Calais
    May 2006
    Its nice that people try to supply wiring diagrams, but i would stay away from that method, especially considering I have done the mod, with the aid of my father whom is a qualified auto electrician, and the above diagrams do not match my vn. It is a good idea to make your own diagram using both the wiring schematics form your manual for your model, and to check the new dashes out assignments, otherwise everything else you said pretty much sums it up. GREAT UPGRADE, doing the Climate Control system next. Cant wait.
    PS: You got your dash pretty cheap too, I payed $135 for it, very good nick though. Make sure the flexible circuit is OK by examining it carefully upon purchase people, and check all that all the bulbs are working and making good contact.
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Stocky, This might just be the inspiration I need to add the guide for the LCD screen colors.
    MaT
    P.S- I got my dash & loom for $45 from wreckers, no bleeds in LCD's or anything Installed mine over 2years ago now.
    The best way is to lay both your s1 or s2 cluster an your s3 calais cluster down, and map out where each plug/wires go, it says it on the Flexi PCB, just map it out an you will know what wires you will have to bridge/add for the 4th plug an switches on the left.
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    Doctor Sodways's Avatar
    Doctor Sodways is offline Legendary Baby!
    Slammed VeeDub Rat and a Brunette...
    Sep 2005
    Behind a Camera...
    Hozy, is your VN a series one? I really want the calais dash, i already have the trip computer buttons and all, but still the level two cluster, id much rather the level three over the VR police spec one i have. This might be just what i need to get it in there though
    Nice write up stocky
    I used to play sports. Then I realized you can buy trophies. Now I’m good at everything.
    The best car safety device is a rear-view mirror with a cop in it. ~ Dudley Moore.
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    I got a S1 VN
    MaT
    kitto Guest
    hey guys I am new to the site and new to driving a holden. I have a vn berlina and I want to upgrade to the calais dash but mine only has a speedo and no tacho. what do I need to do to wire it all up?
    Sep 2005
    Behind a Camera...
    Berlina with no tacho, thats odd, i thought that all the berlina's had the level two clusters in them, interesting, maye your cluster has been swapped at some stage
    kitto Guest
    well I bought the car off a mate and it has berlina badges both inside and out side, is there anyway to tell if it is a berlina or a commodore
    nsladden's Avatar
    nsladden is offline GET UTED
    1992 Holden VP Ute S 5.0L & 1989 Holden VN 5sp Wag
    Sep 2005
    Murwillumbah
    Jun 2005
    Quote Originally Posted by kitto
    exactly what i show in the first post. my vn berlina didnt have the tacho dash, so it is possible
    what year is your berlina? it might have the loom there already
    kitto Guest
    Jun 2005
    its most likely a berlina. its not like someone is going to make a berlina mock up. theyre pretty much the same as an exec.
    anyways. what features does it have? electric windows, velour seats?
    does it have a berlina paintjob, such as the white paint with the black stripe around the car.
    better yet. got a picture?
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    very good stocky, one is needed for the vr/vs section too ive done the mod but i aint good at explaining things :P
    Current: My Ride
    VY Series 2 Berlina, Leather
    Previous: Ride 2
    VR Executive, 5 Speed Manual, Ecotec 3.8
    kitto Guest
    The car has nothing like central locking, power windows, good seats. It is as stock as.
  15. #15
    nsladden's Avatar
    Sep 2005
    Murwillumbah
    Have a look in your owners manual and it shows you how to 'read' the VIN number, I would type it up for you but its dark and cold so im not going outside to get the manual.
    I FRYED RICE!!!
  16. #16
    VN Exec to Calais
    May 2006
  17. #17
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Quote Originally Posted by lsprewell
    Those diagrams are mine and are for a vp that I did about 5 years ago before the install was popular.They are how I wired mine and it works perfectly and has done for 5 years. Information is free ....most people who use them recognise that they arent exactly correct for all vn/ps according to their cars equipment and build date and have to be treated like that ....not just blindly used without any research .
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  18. #18
    Jun 2005
    ah well its good to know who created them. thanks for that. the diagrams seemed to be fine when installing into my VN, and if they work in the VP, i dont see what the problem is
  19. #19
    VN Exec to Calais
    May 2006
    Nice job markovr, i was wondering who came up with them. I too have my own personal coloured diagrams i have made for my VN series 1 for future reference, although its mostly a reference thing.
    And stocky, i have a VN and the diagrams do vary, sorry but they do. And VP's are different , its a manufacturers thing, swap a couple of wires, keep everyone guessing LOL!,
    If you dont beleive me about the differences even within same models, go do some research and you will see i am correct, its not an unsolvable problem, its just one to look out for!
  20. #20
    Jun 2005
    why dont people get it. these diagrams were fine for my VN. maybe the later 1991 model VNs had a different wiring loom, but these diagrams worked
  21. #21
    VN-88's Avatar
    VN-88 is offline fiery red vn manual
    vn v6 s1 manual
    Aug 2005
    victoria , lakes entrance, u live there tell me!!
    hey stocky, ive got the trip buttons coming, and ill have a stage 3 gauge soon. i also have the forth plug from markovr. and a wiring diagram from him, the forth plug has heaps of wires coming of it. so do i need any other plugs??
    check my ride
    http://forums.justcommodores.com.au/...ad.php?t=16665
    and feel free to comment
  22. #22
    Jun 2005
    it would help if you got the plug that goes into the back of the switchblock. it will make it easier to connect the new wires to your existing plug
  23. #23
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    ah ok, will a berlina have the right plug, even if it didnt have a stage 3 dash? or will i need one from a calai?
    check my ride
  24. #24
    VN Exec to Calais
    May 2006
    You will need the 4th plug off a calais VN-88, and by the way Stocky, my VN is a 1990 model Series I and the wiring diagram was close, but not the same, sorry to dissapoint your theory.
  25. #25
    Jun 2005
    read it again genius. my "theory" was that maybe the SERIES TWO had a different loom. jesus christ
    an VN-88, berlinas wont have the right wiring, so just go look in a calais for one
  1. Converting Series 2 VY Berlina to Calais
    By Calaber in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-12-2007, 03:53 PM
  2. converting a executive to a calais
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-03-2007, 05:00 PM
  3. Converting VR Executive light to a VR Calais interior light...
    By sverzijl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2006, 09:46 PM
  4. VK Calais dash into VH
    By bacon-n-eggs in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-09-2006, 11:28 PM
  5. vp how to change dash to calais dash
    By hoon1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2006, 07:35 PM
