Results 1 to 7 of 7
Thread: How do you tell???
    dam13n's Avatar
    dam13n is offline Rice Smoker
    VN 3.8L Exec
    Aug 2005
    Default How do you tell???
    I was just wondering how you tell the difference between a series 1 VN and a series 2?
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by dam13n
    Check the engine - series 1 has the top radiator hose running to the rear of the engine. Series II has the top rad hose to the top of the water pump as normal.
    Reaper.
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I thought this was a reopen of the last one just the same
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    Darren's Avatar
    Darren is offline Site Administrator
    HSV Clubsport R8 E2 M6
    Feb 2003
    Didn't they also fix the problem in the 'Series 2' where you could actually life the windscreen wipers up as well without hitting the bonnet?
    Frd_thmsn Guest
    Quote Originally Posted by Darren
    And isn't that damn annoying. The dudes at our local friendly servo, have done this to me a few , times, grabbed the wiper arm and tried to wrench it up, hitting it hard against the edge of the bonnet. Now I just tell them to keep their filthy water away from my car
    missus (in more ways than one)
    Sep 2005
    different cooling system, (series 2 has cap on rediator and just overflow bottle, series 1 the bottle is a vital part of the system) thermostat housing if located in front of the manifold on the series 2's where as the series 1 the tope coolant pipe goes around to the back of the motor. series 2 has a different fuel rail, series 2 has an updated coil pack, series 2 has an inspection cover over the flywheel (auto) as the series 1 does not.
    probally a bit more to see
    as for what you cant see series 2 has an 8 bolt flywheel series 1 has a 6. series 2 came out with a restrictor bellmouth inside the intake. and a heap of little shit.
    also their was a few models released along the way
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    the changes between series 1 and 2 engines are quite long...buy a gregory's manual if you want more info. I could type it out but would take an hour or so. Lots and lots of changes.
