Results 1 to 7 of 7
Thread: Vp problem HELP !!!!!interior light problems
    Ygoford's Avatar
    Ygoford is offline YGOFORD?
    Vr
    Mar 2006
    Question Vp problem HELP !!!!!interior light problems
    my mates just brought a vp for 2500 that has done 160,000 ks and is imaculate i told him its underpriced but thats not the issue the issue is that his interior light didnt work so i replaced the light globe and the fuse and it does but instead of turning off it just dims :S help !
    With Great Horsepower Comes Great Irresponsibility
    VX HSV Clubsport
    Jun 2005
    Sydney, eastern suburbs
    yeh mate, im guessing that it might be a calais?? thats what they are programmed to do, you can change the dim, for longer or shorter, im not sure how but i know i read it somewhere maybe on this or in a gregorys.
    THERE IS NO REPLACEMENT FOR DISPLACEMENT
    Ygoford's Avatar
    Vr
    Mar 2006
    nope exectuive and i didnt look for the change thing but when its suppose to go off it doesnt
    253@7k is offline 300rwhp supra. yay.
    TT Supra/HZ Ute.
    Apr 2006
    Check the switches for when the doors shut, if one of those is stuffed it will stay grounded and not disconnect, Therefore the light will stay on.
    Hope this helps,
    SLundy
    VN Berlina V6
    Jun 2005
    I know this might sound stupid, but check that the switch on the dash for the interior light is not pressed, happened to me... Dont know if the VP has one but im assuming it does.
    never late in a 308
    HATER VP Guest
    Yeah it has one.
    Hold the switch in on each door to see if it turns off after the delay.
    If it dosent you will have to look closer into each switch because thats probley what the problem is. Also check each side of where the switch sits.
    It seems it could be just about shitting off if it dims.
    Ygoford's Avatar
    Vr
    Mar 2006
    done all that it didnt work i did that to start with , the ignition light does it aswell like the one near the key hole , think its suppose to ? neways it doesnt turn off i reakon its a eletrical problem ?
  1. Vt interior light problem
    By Charg'd in forum Electrical Wiring / Questions
    Last Post: 10-04-2007, 06:49 PM
  2. Converting VR Executive light to a VR Calais interior light...
    By sverzijl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2006, 09:46 PM
  3. Interior light problem...
    By VL2NV in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-11-2005, 09:27 PM
  4. trouble with indicator & interior light problems
    By slwbt1 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-10-2005, 08:35 PM
  5. Interior Lighting Problems - VK
    By TheKnightTemplar in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-07-2005, 07:54 PM
