Results 1 to 13 of 13
Thread: fuel pump repair help needed
    cass83 Guest
    Exclamation fuel pump repair help needed
    I am going to be changing my fuel pump in my VN and would like some help please, does anyone have a copy of a workshop manual with information on changing fuel pumps that they could scan for me, I cannot afford to buy a manual and would like to have this information handy so I don't screw up.
    Cass
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    hahaha my expertise! I've done so many of these...
    That'll teach me for my "pffffffft, EMPTY?, we've still got like 60 k's left!"
    There's a whole sender/fuel pump unit in your fuel tank, it's kinda just behind the diff, on the drivers side of the car.
    you might want to jack that corner of the car up and chuck it on stands.
    the sender is the round plate looking thing in the fuel tank
    disconnect the fuel lines and plugs going into/out of it, then there's a few I think 7mm bolts holding the whole sender unit in
    undo all of them, watch the cork gasket (might be worthwhile getting a new one)
    pull the whole assembly out, while twisting it and turning it to get it out - watch so that you don't hook anything on the inside of the tank as you're pulling it out, because you don't want stuff falling off...
    some bits may be a sh!t to pull out, but just wiggle around and you'll be laughing.
    It might be worthwhile mentioning at this point that if you have more than 1/8th of a tank of petrol at the moment, you'll be soaking in the stuf unless you drain it.
    you'll see the pump at the end of the sender unit once it's all out
    pop old one out, new one in, clean filter
    and installation is reverse of removal
    cass83 Guest
    cheers for that mate, I'll do it tomorrow (it's kinda dark now) and let you know how I got on
    VN Exec to Calais
    May 2006
    If you are reall keen i got some pics for a DIY job, similar procedure as above but with photos courtuesy of streets commodores
    cass83 Guest
    yea photos would be great I will PM you my email addy,
    the fuel pump should be delivered around lunchtime so I can't do it till this afternoon,
    BUT - will I need to reset the computer after changing the fuel pump?
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    If you disconnect the battery you will.
    Gravity is proof that nature keeps getting us down.
    cass83 Guest
    thank you mouce, should I disconnect the battery or can I do it with the battery connected?
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    do it with the battery conected just make sure the key isnt ON you can have the key on accessories to listen to music if you want.
    mouce's Avatar
    Jul 2005
    ^^^damn straight, can't work on a car without music or beer. Might as well listen to the sound system in the car. The only time I've ever had to disconnect it was when I was re doing the loom to the head unit and when I replaced the battery. Otherwise, I keep it connected if I possibly can.
    VN Exec to Calais
    May 2006
    There is no harm in disconnecting the battery in your car. I have done it quite a lot, especially when doing modifications, but its not needed. What you need to remember is to let the pump prime for about 10secs after you have finished installing it, and than start your engine.
    Keeper85's Avatar
    Keeper85 is offline Keeper
    90 VN
    Jun 2006
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Oh, just on a special note... Take CAREFUL notice of exactly how you have to turn and pull the fuel pump unit to get it out... even write it down. Because otherwise you'll be under there for an hour screaming at the ****er 'cause it won't go back in
    The 1972 HQ Kingswood
    Burnout_bro's Avatar
    Burnout_bro is offline Donating Member
    HYPER VX SS/ R33 GTST
    Dec 2006
    yeah that happend to me got it out then couldnt get the mofo back in bastard of a thing
  1. help needed with vr fuel pump
    By Raven_2656 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-08-2011, 02:49 PM
  2. Help needed, suspect oil pump.
    By J_D in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-09-2006, 12:48 PM
  3. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  4. cold weather fuel repair cautions
    Last Post: 10-05-2006, 10:16 AM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
