Results 1 to 3 of 3
Thread: stops when driving along
    DAROKA Guest
    Default stops when driving along
    having trouble with my VP it just loses power when driving along had the petrol tank and pump checked alternator and replaced the crank sensor. someone said it could be the Dwell angle. Can anyone tell me the real problem or help in some way.:b:
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    is this power as in electrical?..or power as in accleration?..or both?
    i had a problem a while back where the whole car would die on me whenever i flicked on my high beams, just for a second then go back to normal...
    ended up being my battery, so chucked a new one in and its never done it since.
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Check out your leads, and coil pack.
    Also, if you have an aftermarket alarm/immobiliser fitted make sure that it's behaving properly. I had something like that happen to my VN and it turned out that the immobiliser was cutting in while I was driving and taking out the left bank of the engine. It would idle on three cylinders but wouldn't move the car. All because of one dodgy connection.
    Gravity is proof that nature keeps getting us down.
  1. car starts then stops
    By System in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-12-2007, 11:06 AM
  2. bump stops vs ute
    By vs-s-pak-ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2006, 01:07 PM
  3. Bump Stops?
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2006, 07:38 PM
  4. Car just stops and after 10 min starts again
    By shillanda in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2006, 08:47 PM
  5. Starts and Stops VN
    By vn_calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-12-2005, 12:54 AM
