Results 1 to 5 of 5
Thread: fuel fuse blowing
    adzo Guest
    Question fuel fuse blowing
    new to this site hello everyone, Ok my problem is the fuel fuse keeps blowing sometimes when I have had the car running and then other times as soon as the key is turned on. 1/ have replaced the internal fuel pump.
    2/ Replaced fuse and relay. 3/ _HELP_____ still blowing fuses,
    Just a foot note I live 80klms from town.
    adzo Guest
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    the power wire to the fuel pump probably has a cut in it. i dont know where it runs but if you put it on ramps and follow the wires from the pump back to the relay you will find the problem.
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    VX HSV Clubsport
    Jun 2005
    Sydney, eastern suburbs
    the wire runs down the side of the car (inside under the feet step) its a purple wire, not sure which side but take it to an auto electy and they cause use a multimeter and test if the wire has a break in it, and should be able to tell you what the prob is
    THERE IS NO REPLACEMENT FOR DISPLACEMENT
  1. Need Help VT fuel pump fuse keeps blowing???
    By dieselmc in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-02-2011, 09:33 PM
  2. vn hazzard fuse keeps blowing
    By whatawookie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2007, 01:12 PM
  3. A/C blowing fuse VP
    By twasm6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-12-2006, 07:29 PM
  4. fuel pump fuse keeps blowing
    By stmcomms in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-11-2006, 11:54 AM
  5. main fuse keeps blowing up
    By vnv690 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2006, 11:11 PM
