Results 1 to 6 of 6
Thread: brand new key doesnt work. help plz!!!
    vn executive
    Sep 2005
    Default brand new key doesnt work. help plz!!!
    hey guys i got a new key cut from they key code but for some reason it works only in the doors and not the ignition or glove box. is this just because it needs a little bit of wearing in ?????
    VN 5 spd/VR Calais daily driver
    Mar 2006
    NZ
    Did you get the right key cut? On mine I've got a key that only does the doors and a key that does everything.
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    did your original work the glove box? ive had 2 vns here swapping motors and boxes and both had 2 keys 1 for the door and ignition and 1 for the glove box and boot
    VN Calais
    Feb 2006
    GolD Coast
    1 key should open all unless car has had lock or ignition barrels changed due to theft, you can have the locks calibrated to the one key by a locksmith, no idea what they would charge thou.
    VN Calais
    Feb 2006
    GolD Coast
    SUPERCHARGED VP COMMODORE
    Feb 2005
    Ipswich
    Quote Originally Posted by guss
    get yourself some graphite powder from your local hardware ( this is a dry lubricant much better for locks than RP7 or WD40 never use these in locks as they eventually clog up your locks ) ANYWAY put some graphite onto key and work in and out a few times then turn key over and do the same then try turning the key . This should loosen everything up and after a dozen times of starting you should be right. As you said prob. a bit to Sharp for the old lock.
    This is of course if the locks havent been changed as mantioned before.
    Try all your locks boot and passenger as well just to make sure.
  1. VP Speedo doesnt work then works!!
    By bladerunnerkim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2007, 12:48 AM
  2. My heater doesnt work properly......
    By VQXTC in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-09-2006, 07:58 AM
  3. engine just doesnt want to work.......
    By 9898989 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-07-2006, 05:51 PM
  4. steering lock doesnt work
    By garfa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-07-2005, 07:23 PM
  5. Ignition randomly doesnt work
    By Trewman in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-01-2005, 07:38 PM
