i have just got a pair of vr door pods and about to try and fit them to my vp door skins.. anyone got any advice looks to be a little difficult and window winder is guna be very clost to pod... ideas?
yea anyone got sum advice cause im lookin 2 get these aswell
Check Out My Ride Here: 91 VN Calais[/CENTER]
Just measure an she'll be all good
Take your time.
MaT
P.S- Check the gallery on my website in my sig, Has some old pics from when I was fitting mine.
Originally Posted by garth
yeah its a little bit fidily. measure twice cut once.
if i can do it anyone can![]()
fu2, I did it when I was 15... therefore anyone should be able to do it, Measure Thrice cut Twice.
MaT
thanks for that im guna give left hand door ago over next few days so i will let u know how it goes.. have done lots of stuff to my car in recent months so will have to get some pics and show you all how it has turned out..
I bought VR skins with pods attached. I removed my VN skins and the pods off the VR ones. Layed the VR skins on top of the VN ones and pushed a pen throught the holes and traced the main speaker hole. Jigsawed the big hole out, drilled the small screw holes and the pods went on perfect first pop.
Now mounting the speaker mounts to the door was a bit trickier..bit of guess work combined with trial and error.
i've currently got mine and they line up on the grouves at the front but not the back and have to be on the edge of the bottom , if that makes sense to u then yeah will be goodmine weren't that hard to do the hard part is to get the speaker hole in the right place with the door , door trim and the pods other then that its fairly easy mine look good im still waiting for someone to explain how to put pics on here i;d show u
With Great Horsepower Comes Great Irresponsibility
I did my VN door pods using VS ones, and found that if you line up the front of the pod (speaker end) and make it overlap and the front of the door, it fits in snuggly, keeping it down as low as possible ensures you have plenty of room between the window winder and the pod. Great little upgrade this one!!
http://web.aanet.com.au/hozy/images/11.jpg
http://web.aanet.com.au/hozy/images/10.jpg
http://web.aanet.com.au/hozy/images/15.jpg
http://web.aanet.com.au/hozy/images/int_ds.jpg <- recent pic, shows how the pods still fit in with more interior changes.
MaT
