Results 1 to 6 of 6
Thread: Fuel Injector Rail Bolts
    crazyspoon05's Avatar
    crazyspoon05 is offline Penguin Whisperer
    The 'Bizta' VNVPVR Wagz
    May 2006
    Default Fuel Injector Rail Bolts
    Hi All
    Was trying to track down an oil leak from the valve cover area of my car, removed valve covers and changed gaskets then realised there was a bolt missing from the fuel injector rail on the drivers side of the block.
    Would this be the cause of the leak and if so does anyone know where I can source these bolts from without having to buy a complete set or if I can just put a bolt the same size from something else in there instead ?
    Thanks in advance
    VR Berlina wagon
    Oct 2005
    Default fuel rail bolts
    the fuel rail bolts are nothing special - they just hold the fuel rail down.
    just replace the missing one!
    It is unlikely to cause a leak as they screw into a blind hole in the manifold - the bolt doesn't block up any hole as such...
    May 2006
    Thanks for the info, I actually looked again and it isn't a fuel rail bolt after all, theres a hole beside the drivers side rocker cover (left hand side when facing engine from the front of the car) where the fuel rail curves around from.
    Will try to post some pictures tomorrow as too dark now but does anyone else know if there's supposed to be a bolt in this hole or not as this is where the oil is coming from ?
    Thanks in advance
    May 2006
    Haven't had time to get a pic during daylight of the engine because of work but it's the area circled here, is there supposed to be a bolt or something in this hole or is it something else ?
    Thanks in advance
    Attached Thumbnails Attached Thumbnails Fuel Injector Rail Bolts-a6_1_b2.jpg
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    that should be another blind hole from memory, but one of the gaskets could be leaking around that area.
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Pop down to your local do it your self wreckers and don't forget to take your pocket puzzlers.
    Never knew the S1 Buick had black fuel rails.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  1. Where can i buy Fuel Rail O-Rings from????? Help!!
    By ssn8r in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-10-2006, 01:07 PM
  2. Wtb: Vn 5ltr Efi Fuel Rail
    By Dan355 in forum Swap / Wanted to Buy / Trade
    Last Post: 06-08-2006, 10:35 AM
  3. fuel rail
    By brett 46 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-05-2006, 09:38 PM
  4. Steel Fuel Line Into Fuel Rail Question
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2005, 09:50 PM
  5. Dodgy fuel rail?
    By Blown in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2005, 02:51 PM
