Results 1 to 3 of 3
Thread: vq stato
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    not telling
    Space Invaders Champion!
    Oct 2002
    Default vq stato
    2morrow im heading off to look at a vq stato, series2.
    got a few questions
    1. the 5tlr motor, anything in particular i should be looking at there
    2. will a vnv6 s2 auto fit behind a vq stato (reason is my gearbox in the vn was rebuilt no more than 3 months ago, so when i get rid of my vn i dont wanna loose out with gearbox replacement
    3. any other little body issues i should be looking at?
    cheers
    garth
    i am the god of britany spears womanizer on just dance on the wii
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    The gearbox should bolt up with an adaptor from what i know..... There the same gearbox....
    Just look at it the same wat you would look at a normal vn-vp.
    Rust top of back window, Listen for a miss at idle, Take a look underneath for any oil leaks.
    One thing i do when i go, I take a rag, an I check all fluids on the cars..
    I see if theres black oil... (needs oil change)
    How the PS fluid is.
    How the transmission fluid is.
    I check them just to see if it's been looked after atleast.
    Makesure climate control works. And take her for a drive, listen for any knocking noises or anything mate.
    MaT
    P.S- Goodluck!
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    vq rat's Avatar
    vq rat is offline vq rat
    vn bt1 burnout weapon
    Mar 2006
    hamilton vic
    I think you will find that the auto will be different they are weaker as they are for a v6 , converter will be different too bellhousing bolt holes will not be the same as well put a 5 or 6 speed in her for some fun if the auto is up the creek
  1. My Vs stato
    By Dungeon_Source in forum VR - VS
    Last Post: 31-05-2009, 02:10 AM
  2. My VQ Stato
    By sxchsv in forum VN - VP - VG - VQ
    Last Post: 01-11-2007, 09:09 PM
  3. The other WH V6 Stato
    By Sphinx in forum VT - VX - VU - WH - V2
    Last Post: 24-08-2007, 10:05 AM
  4. WH Stato v6
    By mattman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-04-2007, 09:22 PM
  5. '95 VS Stato
    By Sphinx in forum VR - VS
    Last Post: 16-11-2006, 02:30 PM
