Results 1 to 13 of 13
Thread: NEED HELP coverting to level2 cluster
    VN S2/ Original XRGT
    Jun 2006
    Default NEED HELP coverting to level2 cluster
    I heard you can plug a level 2 cluster with the tacho on the left straite in to your car with no re wireing anyway i got a level2 cluster out of a vn lexen the other day and i replaced it with my level1 cluster and it started smoking a little bit from behind the tacho where it plugs in.Is it because i got it from a vn lexen? when i took the cluster back out i noticed that behind it at the back where the plug plugs in for the tacho that one of them metal strips through the thick plastic that covers the back of the cluster had melted a little bit.I also noticed the plstic on the back of my level1 is blue where as the plastic on the vn lexen one is green does this mean anything?.What do i look for to make sure i have the right cluster is there any special numbers? or anything
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Nasty! ................... Wiring differences?
    Put both clusters face down an see if all plugs go to the same thing, The plugs should be mapped with wire point names an what they do, check through it if there the same, I dunno man.... Sorry.
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Quote Originally Posted by chopsy
    cos you haeva lexcen id say your in trouble to begin with lol... as hozy said, map the clusters out using the pcb key... if they match, you dont ahvea problem... im guessing cos the smoke got let out, they will be different... can you try wiht another stage II?
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Jun 2006
    Thanks for the help fella's but i've got the vn i got the cluster out of a lexen should series2 vn have the level2 dash already?
    With looking at both clusters upside down i have done that sort of but on the level 1 cluster the left plug is your fuel the middle is your speedo and the right plug your temp and on a level2 cluster the tacho is on the left and your fuel gauge is on the right with the temp.I noticed on the level2 cluster from the lexen that on the little strip with the indecator and light picture that the lexen had alot more like power,abs,cruise,fuel and stuff like that i'm thinking that i should go for the lvel2 cluster with the green around the dials the same as my level one has should be the same then i hope anyway
    May 2005
    .....SE Burbs
    nah, series II means ### all in terms of options.... stage II and III is a berlina, calais staesman thing..... so no.... doens't matter if its out of a lexcen though... if its a vn lexcen and a vn commy, no dramas
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
    Jun 2006
    Maybe i got a bodgy cluster thats why it would'nt just hook straite up with out any problems
    May 2005
    .....SE Burbs
    Maybe.... my I to II wokrd fine.....
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
    Jun 2006
    I'm going to get another level2 cluster now from the wreckers so i'll let you all know how it goes.
    Jun 2006
    Well got my new level2 cluster works perfect the cluster i got out of the vn lexen looks almost the same but it's differant thats why it smoked i suppose anyway i'm happy now.
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    how much did u pay for the cluster? did u get it from the wreckers? i need to get a level2 cluster. Is it hard to put in? Do you have to do any rewiring for the tacho because my cluster doesnt have a tacho at all at the moment. cheers
    May 2005
    .....SE Burbs
    Quote Originally Posted by coolvncommodore
    Ok, last time im gonna answer this question ever i think.
    __________________________________________________ __________________________________________________ ___
    Cluster Types:
    (From Left to Right, Top to Botom)
    Stage I = Fuel, Speedo, Temp
    Stage II = Tacho, Speedo, Fuel, Temp
    Stage III = Fuel, Tacho, Speedo, Temp, LCD 1 Speed Warning + Various, LCD 2 Instantanious Fuel Consumption XXltrs/100KM + Various, LCD 3 Trip to empty + ODO.
    Models and their Clusters:
    Executives = Stage I
    Berlina = Stage I or II
    Calais, Statesman, Senators etc = Stage III
    VN/VP Cluster Conversions:
    A stage I to II is a simple plug and play swap. Pull your stage I out and slide a II in. From whats been said i am guessing that a lexcen cluster swap is not sugggested.
    A stage II to I is the same... why you would, who knows.
    A stage III upgrade is alot more complicated. There is a sticky in the VN/VP section. Please read that. All cars (VN/VP) can have a stage I,II or a III with a little modification.
    Summary of Stage III Conversion:
    1. Modification of exsisting LOOM
    2. Additional Buttons Required
    3. Modification to ECU loom also required.
    SO! if you dont have a tacho dash, you can simply put a same model upgraded dash in its place,pending its only a stage II, with no modification. A stage III needs modding.
    No more questions about this. Please.
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
    fu2's Avatar
    fu2
    fu2 is offline The Man With No Name
    VP Berlina II - MY10 VE SV6 Ute - VH SL/E
    Jul 2004
    ask you should make that a new post and get a mod to sticky it. might save a few repeat posts
    VN Executive S1
    Aug 2005
    Good idea. make it a sticky
  1. VR/VS Level2 to Level3 Dash Cluster Upgrade
    By wheredoesthisgo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-04-2007, 05:00 PM
  2. Coverting to climate control air con
    By pap in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-02-2007, 05:48 PM
  3. x3 level2 clusters
    By chopsy in forum Parts And Other Items For Sale
    Last Post: 07-10-2006, 03:24 AM
  4. Need help after installing a level2 cluster
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-06-2006, 08:54 PM
  5. coverting vs to manual
    By crainy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-02-2006, 09:19 PM
