Results 1 to 9 of 9
Thread: New injectors vs reconditioned vs cleaned
    VN V6 Commodore Executive....and a London bus
    Dec 2005
    Default New injectors vs reconditioned vs cleaned
    Is there really much advantage in buying new injectors? What's reconditioned injectors, old ones cleaned up? Is there really any disadvantage to just cleaning the existing ones and bunging some new O rings on them?
    Jul 2004
    if u shop around u can pikup new 1's for alot cheaper then a professional clean the injectors in my vp were stuffed i picked up a set of vy v6 injectors brand new for 50buks its runs great and fuel economy is great too much cheaper then 120buks to clean the old 1's
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    go to the wreckers an rip the injectors out of a 2000+ ecotec motor shove em in ur pocket, an nice cheap injectors.
    lol
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    Quote Originally Posted by HoZy
    lol
    MaT
    thats my boy
    naughit mat
    Dec 2005
    Default Great idea...
    never knew commies that new had injectors that fit. Thanks guys!
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    I've been toying with that idea too, putting injectors from a newer model in. Might have to look into it.
    Any ideas on where I could source V6 injectors from in Melbourne without a hefty price tag?
    VP Calias S2
    Jun 2006
    So will ecotec injectord fit all 3.8s?
    Theres No Replacment For Displacement
    vk calais, vn waggon
    Jun 2006
    with anything secondhand u run the risk of them being worse than the ones u have, but saying that with all the v6's i have owned i have neva had an injector fail or needing cleaning, i just replace them every 80,000
    Jun 2006
    woops ended post early
    i just replace with new injectors as with cleaning wont fix if the injector is leaking or not flowing properly and if ur fuel system is dirty enough to block injectors, then just cleaning them wont solve ur problems, id recomend the full fuel system clean and its only $200 at most places
  1. Replies: 16
    Last Post: 03-09-2007, 04:07 PM
  2. Stalling when changing gears(N or R to D) - cleaned IAC?
    By Raging Bull in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2007, 01:44 PM
  3. should you get your injectors cleaned
    By greatone in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2006, 03:15 PM
