I've just installed a level2 cluster which i might say i'm rapped with it anyway everything works perfect except for left hand indecator arrow.My left hand indecator works but the arrow on the dash does'nt work.The right arrow works fine but as i said no left one i've tried changing globes in the back of the cluster but it has'nt help.Has anyone had this problem as well ? please help what could it be ?.
the globes at the back have nothing to do with the indicator. the globes on the bottom of the dash light up that light. just check all 10-20 of them to see which ones are working
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
Are you talking about all those little globes right down the bottom of the cluster? if so i worked out which one was for the indecator and tried acouple of differant globes but still no go.
did u get a vn or vp cluster cause i noticed the indicator may be in a different spot to your old cluster one way to check on the printed circut board there is written digrams for the connectors look and check the indicator is in the same spot on the wiring looms
I think it might be in the same spot but i'll check but the right indecator arrow on the dash is working fine.
i picked up a vp cluster the other day just had to move the wire from pin 10 to pin 11 i think it was just chck the back of the cluster there one pin out from memory
had the same problem, thought it was the bulb so i changed it, still didnt work, so then i thought about it and i just changed the whole fitting thing with another one as it wasnt making contact with the copper tracks and that was all, i used a knife to make sure the copper track was all joined and cleaned to make contact
I worked the problem out it was what donwb said the pin [little glob down the bottom] was out by one just had to put one in eleven.My only problem now is when indecator is on the PWR light flasher's so i jus got to put the right strip with the indecator arrow,pwr,engine, demister in as i got em mixed up with a differant one when i had it pulled apart.
