Results 1 to 12 of 12
Thread: Shudder from rear
    VP Berlina LX
    Oct 2005
    Default Shudder from rear
    Hi,
    My VP berlina has just started getting a shudder/vibration from the rear end only when accelerating from standing start. It only lasts for a few seconds or so. Could this be the tailshaft causing this.
    Thanks
    05 VZ
    Nov 2005
    mate i had the exact same problem up untill last week. Went to mechanic who put in new front and rear universal joints. Fixed the problem up straight away. If its not ur uni joints (which probly could do replacing anyway) then at least u can suss out the diff while your at it
    VX HSV Clubsport
    Jun 2005
    Sydney, eastern suburbs
    yeh thats moss likely what it will be is the uni's or centre bearing,
    THERE IS NO REPLACEMENT FOR DISPLACEMENT
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Just done my tail-shaft no vibration unbalanced feelings anymore under any driving
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    VP Berlina LX
    Oct 2005
    VN S
    May 2005
    Apart from the Uni joints - try doing all notholane bushes throughout. I had same issues got new Upper/Lowing trailing arms and its all sorted.
    Chris.
    beefcream's Avatar
    beefcream is offline Lethal LOKKA
    VS SS 5speed (project) VN exec v6 (daily)
    Sep 2005
    South,Adelaide
    i have a prob where after i start my car, is vibrates and when i put it into gear it like jerks.
    wat could be the cause of this?
    VS SS - Street/Show Project [BEEFY]
    http://forums.justcommodores.com.au/...-beefy-v2.html
    HID Kits from $100 - Installation available PM FOR DETAILS
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Quote Originally Posted by beefcream
    Myn was similar to your going into gear, It still is a touch I'm was told i had play in the tail-shaft, Fixed that it's still there but a little clonk further back now, I'm now told i have play in the diff.
    But after i had the tranny done it jumped forward going into gear pretty hard went back and the guy adjusted the kick down cable that helped a little.
    You just might have some extra play in there i might be 100% wrong
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Try the flex joint if its not the uni joint, its right neer the uni joint. things that may cause it to be the flex joint is a poorly supported gearbox and worn suspension.
    beefcream's Avatar
    Sep 2005
    South,Adelaide
    ill get it checked out when i get a tranny service
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Uni Joints, rear control arms,tail shaft,diffs...
    Abviously something in the drive train so work with that list 1st dude and ull sort it out.
    Cheers.
    * RVN 355 *
    VP SS & VE Berlina
    Sep 2005
    Default Diff shudders
    This is a common problem, I believe that you need to add an additive into your diff cone's. They polish and start to slip, feels really bad in the car. If this is the problem and you leave it to long then you maybe up for a rebuild. No need to panic, you have the good fortune of driving a holden so the additive should be suficiant. Cheers.
  1. Shudder
    By hazza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-03-2009, 06:06 AM
  2. car shudder
    By kunifa in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-05-2007, 09:30 PM
  3. shudder from left rear wheel
    By georgeonboost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2007, 07:24 PM
  4. VT shudder
    By MrE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-03-2007, 05:19 PM
  5. bad shudder
    By 2greedy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-03-2007, 10:12 AM
