Results 1 to 8 of 8
Thread: (help) plz!
    MY08.5 SV6
    Aug 2005
    Loganholme, QLD
    Exclamation (help) plz!
    Hi fellas i havnt been here in a while & i have a problem with my VN calais auto :b: . well what happent about 6months ago the fuel pump stuffed up & i didnt change it so it was in storage till about 2 weeks ago. so i changed the fuel pump put a new battery in it & went to start it... the fuel pump works it turns over like normal but dosnt start . i checked there was fuel goint to the fuel rail & there was. so it has fuel after i worked that out i changed the coil pack & ignition module it still dosnt start. all the relays work no blown fueses.
    HELP PLZ!!!
    Im a true commy boy!!!
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    VX HSV Clubsport
    Jun 2005
    Sydney, eastern suburbs
    crank angle sensor, have you got a spark?? first does it turn over and not ifire or it doesnt even turn over??? if it turns over and doesnt fire theres a good chance that its your crank angle sensor,
    THERE IS NO REPLACEMENT FOR DISPLACEMENT
    MY08.5 SV6
    Aug 2005
    Loganholme, QLD
    yer it does turn over & yes it has no spark so ill chek the crank angle sensor 2morro. thnx for the idea!
    VX HSV Clubsport
    Jun 2005
    no spark and turns over, yeh it definately sounds like the crank angle sensor has died
    2004 Black Vz R8 HSV Clubsport 297kw Gen IV M6
    Apr 2006
    South australia , Adelaide
    how much does this cost to fix guys cause mine is stuffed as well..and where?
    =Brock=
    My Ride
    2004 Phantom Black Vz R8 Hsv Clubsport 297kw 6L Gen IV M6-6 speed, Full black leather -
    VP WAGON V6
    Mar 2006
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    I got a second hand sensor for 100 fitted took em 45min to do
