Results 1 to 14 of 14
Thread: vn stutters going around left hand corners
    vn ss
    Sep 2005
    Default vn stutters going around left hand corners
    hi hope sumbody can help me my vn commodore ss is playing up bad. when u go around a left hand corner it coughs and splutters for about 200 mtrs then runs ok till the next left hand corner and it is down on power a little. was thinking maybe its sumthing 2 do with the fuel pump but not sure how 2 test it. thank you for your replys.
    YMY-88U's Avatar
    YMY-88U is offline Donating Member
    Project VH SL/E
    Jun 2005
    could also be your coil pack, check to see if it is all connected properly
    vn ss
    Sep 2005
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    vn ss
    Sep 2005
    thats the funny thing if it was a fuel pickup problem u would think it would happen when fuel is low but does it when ther is plenty of fuel in it
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    vn ss
    Sep 2005
    VY S2 Berlina
    Jul 2005
    vn ss
    Sep 2005
    VY S2 Berlina
    Jul 2005
    could be your fuel pump, dunno howto test, i know howto replace though done ti a few time
    vn ss
    Sep 2005
    vn calais
    Sep 2005
    i have the same problem with mine but mine is when i go right around a corner i have a vn calais v6:b: :b:
    vn ss
    Sep 2005
    last night i took my standard throttle body off my other vn ss (as have had throttle body body issues before) and put on this car. bloody thing wouldnt even start so no go ther. put original back on then checked timeing again noticed that the timing light would blink 10 or 20 times then miss a couple of blinks (had this issue on a normal car toyota hilux 4WD turned out to be the condensor on the distrubitor) So do you think my problem is fuel or electric.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    I got no idea, but i had the same problem on my old Mazda 626. It was great for a year, then only lately it started dropping fuel supply when I took hard right-hand turns. With a full tank, too. If I gave it a full boot of gas, it would just cut out and splutter for a few seconds. Almost like the fuel tank had no baffles ^^
  1. Left Hand Drive license in VIC
    By Jesterarts in forum General
    Last Post: 30-10-2007, 11:33 AM
  2. Removing Left hand mirror
    By strat in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2006, 11:47 PM
  3. Left hand switch block off a VP onto a VN
    By andy05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-06-2006, 06:30 PM
  4. WTB: Left Hand Tail Light For VT SS Series II
    By VTSSDUDE in forum Swap / Wanted to Buy / Trade
    Last Post: 30-01-2006, 12:40 AM
  5. groaning noise from left hand side
    By hdt238 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2005, 11:55 PM
