+ Reply to Thread
Results 1 to 4 of 4
Thread: fuel pump/sender question
    VN S pack
    Aug 2005
    Default fuel pump/sender question
    my fuel pump/ gauge sender looks to be leaking from the cork gasket that seals it to the tank. Could i used gasket goo to redo the gasket so that i don't have to completely remove the unit or do i have to source a new gasket? if so, were can you get them from
    vn hsv sv 89
    Apr 2006
    Definately get a new gasket, if its already leaking and you disturb it gasket goo wont save you. You can buy the gaskets at any parts store if they are out of stock just buy a cork sheet and be sure to use a fuel friendly sealant to help things mesh. Have fun
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself fazz1977 Executive
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    Yep, new gasket. Gasket goo and selastic will only break down with contact with fuel.
    vk calais, vn waggon
    Jun 2006
    make sure to tension the bolt equally and dont overtighten as u will cause the cork to prematurely fail and will be doing the gasket again in the near future
+ Reply to Thread
  1. fuel pump question
    By jas98 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2007, 12:00 PM
  2. VR V8 BT1 Fuel pump\gauge sender Assm
    By muttley383 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2007, 11:22 PM
  3. fuel pump/sender unit re-installation problem
    By sparra_gump in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-05-2006, 04:01 PM
  4. Fuel pump and sender unit
    By scojohara in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-03-2006, 12:51 PM
  5. fuel pump question
    By VNPOWER in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-07-2005, 04:33 PM
