Results 1 to 6 of 6
Thread: VN V6 cutting out
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    Default VN V6 cutting out
    Hi, i've just bought a 1990 VN Berlina V6 that has a few problems at the moment. The biggest of these is that it idles really badly (possibly only firing on 4 cylinders sometimes) and if you turn the steering wheel at low revs, the revs drop down a lot - sometimes enough for it to cut out.
    Any ideas? Its ruining what is otherwise a really nice car!!:b:
    Hot-Rod's Avatar
    Hot-Rod is offline SuPaFlY -LiV3 Surviv3 Di3
    VX Commodore Series 2
    Sep 2005
    Oz
    look into the state of your coil pack about the misfiring makes a car run super rough, also the power steering rack could be the problem with the full lock turning at low revs.
    R Photon's Avatar
    R Photon is offline I Like Bresciani Racing
    1990 VN Commodore
    Nov 2005
    Brisbane,Queensland
    maybe consider changing your leads and spark plugs.
    i changed my leads and spark plugs last weekend for that problem (firing on less than 6 cyclinders)..
    its going all good now...
    spark plugs cost me 3.50 each and leads were 35.00 from Repco.
    56 bucks but worth it ay.
    Shortstuff's Avatar
    1995 VR II V6 Wagon
    May 2006
    I'll change the coil pack and spark plugs first I reckon. The leads look almost brand new! It's also due for a steering rack as the one in there at the moment has a bit of a leak. Thanks for the ideas.
    VN Berlina Series 11
    Jan 2009
    Question weed69
    Does anyone know how difficult/expensive it is to replace the C.A.S. on a 91 vn v6 auto berlina, stalls and won't run properly, until cools down, was told to pour water over sensor to cool!, Also are coil packs for same expensive, and do they include the module
    VN S1
    Jan 2008
    Pretty cheap for a cas on ebay for 45 or so. Pain to change but lol.
  1. VP Air Con cutting out
    By VP-Matty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-06-2008, 10:18 AM
  2. VR ss cutting out
    By SERGE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2007, 12:12 PM
  3. Amp keeps cutting out?? PLS HELP
    By Holdenboy_VS in forum Car Audio
    Last Post: 17-01-2007, 10:57 PM
  4. Amp cutting out!!
    By donz in forum Car Audio
    Last Post: 01-11-2006, 08:37 AM
  5. VX a/c cutting out
    By VX_GIANTZ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-10-2005, 10:24 PM
