Results 1 to 10 of 10
Thread: my clutch is playin up
    vl calais turbs vr 3.8
    Jun 2006
    Default HELP NEEDED URGENT: my clutch is playin up
    hey all another problem with my vn again?? uit seems never ending.
    my clutch is really stiff and when i quickshift from first to second it seems to not give all the way and revvs out and then about 5 seconds after it releases and gets going. same with dumping it not that i do it much but it doesnt lose trraction right away you can have your foot off the clutch and it will still rev and not move anywhere and sometimes it doesnt its weird anybody have any ideas on how to fix it or whether i need a new one???
    Jun 2006
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    Jun 2006
    Boonz's Avatar
    Jul 2005
    $400 for a decent clutch kit..... plus about another $400 for someone to put it in
    VS SS 5.0ltr
    May 2006
    queensland
    might need new cltuch id say no clutch plate but dunno if it takes time to select might need new syncrose for you gear box
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Easiest way to check your clutch is to cruise along at 60Ks in third gear then floor it. If it revs up and doesnt go anywhere your clutch or pressure plate are stuffed. If it only slips for a while after you release the clutch it could be a sticky thrust bearing or slave cylinder or cable or linkage.
    Jun 2006
    yea na even in second at 40 give it flat stick throttle and she revs up real high without a kick down the driveshaft but now i let the clutch out and she doesnt go anywhere at all just revs with the clutch out on the spot
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    Quote Originally Posted by Tree cutter
    4th and 5th would be better to test it wouldnt it. mine slips as well when i change down into 3rd foot flat at about 100 for a few secs. it even did it in first(foot flat again) from take off a whilee ago. i need a new one to lol but i can wait till it does it while driving normal.
    Apr 2006
    Mt Gambier SA
    Sounds like you need a new cluch plate and pressure plate. While you have it apart you should replace the thrust bearing as well because it isnt that expensive and it could be near worn out anyway. Also check the flywheel to see if it has any hot spots on it from slipping. Hot spots are blueish colored patches on the surface of the flywheel that are slightly higher than the rest of the surface which sometimes have small cracks in them. You will need to get your flywheel resurfaced if you have hot spots so your new clutch doesnt slip.
  1. 5.7 ltr Vy Clutch
    By Purplecrewy in forum LSx Development and Modification
    Last Post: 02-05-2008, 10:10 PM
  2. Speedo playin silly buggers
    By Outlaw Torn in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-09-2006, 08:00 PM
  3. how vr clutch goes together
    By krisjanik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-07-2006, 11:34 AM
  4. dash lights playin' up
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2006, 02:30 PM
  5. clutch fan
    By sulley in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-12-2005, 07:59 PM
