Is there a particular tool and/or method for lifting the tensioner to remove drive belt on VP 6 cyl?
an 18mm ring spanner
you could use a socket and bar, you will need to slip the belt over the alt or power steering pulley so that the nsocket isnt in your way
18 or 19mm ring spanner what ever it is and another ring spanner to use as a leaver bar to lift it easily. Then just slid the belt of the centre thingo.. above the harmonic balancer. You will know what i mean when you see it
