Results 1 to 10 of 10
Thread: Bonnet stay.
    Frd_thmsn Guest
    Default Bonnet stay.
    I want to attach a couple of hydraulic bonnet lifters to a VN .
    Could anyone tell me where the bonnet shocks mount to on the body of the car. I,m not sure what models had hydraulic ones, but probably it is in Calais etc.
    The bonnet has a small nut where I can attach one, but I can't see where to attach it on the body.Just thought it might help save a bit of trial and error,
    I have a few hydraulic bonnet lifters and thought I might convert it away from the manual bonnet stay.
    Also do they have one or two lifters for the bonnet.?
    And roughly how long would the lifters be?
    Any pics would be a bonus.
    Thanks.
    foammedia Guest
    Does this help you? They came out on VP's, oh yeah, there is one on each side
    Attached Thumbnails Attached Thumbnails Bonnet stay.-rez0001_1.jpg   Bonnet stay.-rez0002.jpg   Bonnet stay.-rez0003.jpg
    Frd_thmsn Guest
    Thanks for that Jase.
    Exactly what I was after. I thought they may have welded a bracket onto the body for it where there's a rubber stopper at the moment .
    Some bozo , leaned on the bonnet clip the other day , and it being plastic broke off And anyway our crappy old XE wagon even has a hydraulic bonnet lifter, so the VN should have one too.
    VE GTS
    Jun 2005
    Mackay, North QLD
    yeh i put a pair of them on my bonnet, its so much easier and safer then the manual ones
    THERE IS NO REPLACEMENT FOR DISPLACEMENT
    Jun 2005
    how did you install them? was it hard, cause i want to do this too
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    i want to do it aswell!!!
    what sort of hydralic thing are they?
    can you use the ones that hold the back up on the wagons or are they different?
    Adam
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    You can get the bottom bracket and bonnet struts from some VP's and VR's and VS's as well...they are all the same. Theres already a spot to fit the bracket on the VN's as well as a spot on the bonnet to attach the top of the strut.
    What I dont understand...is how the hell you attach the top to the bonnet where the hole is...
    PaRaDoX's Avatar
    PaRaDoX is offline Not a chev.....
    VZ Calais LS1, VT S Supercharged V6
    Apr 2005
    Melbourne, Victoria
    looks like they have to be welded onto the side guard, looks messy especially if u wanna remove the side panel,
    1991_Vn2nV's Avatar
    Mar 2006
    Nah you should be able to pop rivet them or screw them on...the brackets that is on the bottom
    1991_Vn2nV's Avatar
    Mar 2006
    I just searched the forums and found a really good thread with pics on this topic:
    VN struts
    Note how they mention to replace the the normal bolts in the side guard bits above the bonnet struts to the flat type found on VS commodores or you will end up with a bent or misaligned bonnet
  1. Bonnet release cable snapped how do i open the bonnet
    By S-Pac_Sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2010, 08:07 PM
  2. HELP! Where am I going to stay?
    By chappy in forum The Pub
    Last Post: 08-12-2006, 09:36 PM
  3. Should it stay or should it go?
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2006, 02:23 PM
  4. Places to stay?
    By coolvxss in forum The Pub
    Last Post: 25-09-2006, 07:43 PM
  5. headlights stay on!
    By wayno55 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2006, 06:54 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
