Results 1 to 2 of 2
Thread: Cracks in CAT
    VN-Series I-6-90
    Apr 2006
    Default Cracks in CAT
    Just replaced my CAT and am suprised to see that it was still in there. The flanges had little hairline fractures in the welds about say 70% of the way around i could see the sooty deposits there where it had been leaking. So i scored another one from the wreakers for $45 and i cleaned it up and checked out the welds. Same style of crack only about 5% this time though and one end only. So i took to it with the welder after taking off the heat shield sorted it right out. Whack the heat sheild back on, done.
    Thought id post this up as it seems that it could be a common problem, nothin else really wrong with either original, or CAT from wreaker, few welding rods are cheaper than a new CAT
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Yea, I just got a used cat off the wreckers for $60. No rattles, perfect flanges, just a little surface rust. Two new gaskets cost me $6, and off it goes! Well, tomorrow. If it doesn't rain. I'll let you know if it all works out how it's supposed to
    The 1972 HQ Kingswood
  1. Repairing a bodykit (cracks/chips)
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2006, 05:07 PM
