Results 1 to 16 of 16
Thread: help with timeing my vn
    vn ss
    Sep 2005
    Default help with timeing my vn
    hi need to check the timeing on my vn 5lt v8 has a cam and chip package in it and sumbody told me that will change your timeing from the 10 degree factory setting just wondering if this is so many thanks
    VX Series II SS BLACK M6
    Sep 2005
    reservoir,melbourne
    vn ss
    Sep 2005
    Sep 2005
    reservoir,melbourne
    vn ss
    Sep 2005
    vn ss
    Sep 2005
    vn ss
    Sep 2005
    Sep 2005
    reservoir,melbourne
    dialing a cam in means that the cam has max lift (valve fully open at induction stroke, same on exhaust) if it hasn't ya wont get full performance from cam. As for timing it, you are gunna need to advance it, go two degrees and see if it pings under load, then another two,etc... ya gunna have to time it by ear, and experiment, good luck.
    Sep 2005
    reservoir,melbourne
    on the spec sheet that came with the cam it should give you a starting point to time it to
    vn ss
    Sep 2005
    vn ss
    Sep 2005
    vn ss
    Sep 2005
    vn ss
    Sep 2005
    Sep 2005
    reservoir,melbourne
    Quote Originally Posted by prjacksonau
    oh u mean start at 2 degree and keep advanceing till its right
    i mean start at the factory timing mark and advance by 2 degrees each time till it dont ping under load, remember to remove the vacuum line off the disy when doing timing (if it has one cant remember, been a while since a f#cked with 5.0l) advance is the direction the vaccum advance line comes off.
  15. #15
    vn ss
    Sep 2005
  16. #16
    foammedia Guest
    Hey woo, for doing the timing on the 5 liter you short out the aldl plug so it's in dianostic mode, same as checking for errors then you use your timing light and adjust the dizzy till it's at 10 degrees, for go fastness your going to run 12 or 14 degrees at least with higher octane fuel
  1. is this lifter noise? or timeing chain..or neither
    By jas98 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2007, 08:08 PM
  2. Timeing gears
    By CHANDLC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2007, 04:11 PM
  3. Timeing belt ?
    By hN! in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-04-2006, 01:39 PM
