Originally Posted by
chopsy
Hey all all my dash ,ciggie lighter, lettering on console lights are all working but my lights in the heater and aircon switch's are not working has anyone had this problem ? or doe's anyone know what the problem should be ? any help would be helpfull.
I doubt is the fuse. Check all your lighting fuses first though. I would think the ciggy light/console light is on the same circuit.
MINI TUTORIAL (YES I'VE JUST DONE THIS, AND ITS A S**T OF A JOB!)
Problem is, replacing the globes isnt that easy in the heater switch. You need to take off the panel where your automatic or manual shifter is. To get the panel off, you'll need to put the auto is a lower gear, turn the panel sideways, maybe depress the button under the T-BAR and wiggle.
Once you've got that off and unclipped the wires to the ciggy lighter, you will see under the centre console panel a couple of screws (should be 3) Unscrew them and take panel off (I think you might take the aircon button off first, just PULL) After that panel is off, you will see more screws holding in the heater panel on your right. Remove them. Now, go to the driver's side. Crouch down and look at the BACK of the centre console (near driver's foot rest) you should see the end of a rod, and at the end of that rod, a whitle clip. Use a small flat bladed screwdriver to remove the clip.
Back at the front of the console, pull off heater and position knobs, then remove panel. Pull out white back part. You will see its held in by several electrical plugs. Unclip them. There is also a black vacum plug. Unplug it (it will make a gushing noise, but its OK) Now you have the unit out. Drive down to Repco or somewhere similar, show 'em the bulb, get new ones.
Put your hand at the back of the unit when replacing bulbs, to steady the bulb socket. Put control panel back in, redo all the electrical/vacum plugs CHECK AND SEE IF IT WORKS FIRST before you put the rest back together.
Reinstallation is the reverse of Deinstallation
I might add the lower of the stock bulbs is usually covered by a white cap. I replaced mine with a normal clear bulb, and it looked better and brighter after this!
Ah, nothing like a Datsun 120 WHY!
