Results 1 to 7 of 7
Thread: knock sensor issues
    VN v6 s2 Berlina 5spd
    Mar 2006
    Default knock sensor issues
    By the way its a vn series 2 v6 manual.
    i had my engine light come on a while ago.
    Any way i did the "paper clip trick" and got
    code 42:knock sensor.
    I was wondering if anyone else has had to change this part?
    Are They cheap?
    Are they Easy to install?
    What do they do/ measure?
    If anyone can help me it would be muchly appreciated.
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    sorry mate i dont know!!!
    but i would like to know for future referances
    Adam
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    get one from a wreckers they are damn expensive brand new from memory over $300 they are simple enough to replace they just bolt into the block you should be able to get it in and out without removing anything else
    i do warn you thow the knock sensor retards timing when pinging is detected and while it is broken you run the risk of damaging your engine
    im not admiring your car im looking in disgust
    Jan 2006
    stanthorpe, qld
    VP Executive R-spec
    Jan 2005
    It detects pinging and pre detonation in the engine and retards the timing to stop things breaking but the bad part is it can go off with all the vibrations in the engine and make you go slower than you should.
    Also worst of all for you ahszv6, is that when it gives an error code the ecu will pull out heaps of timing as a failsafe mode and your car will be a total slug. But I'd test it again to see if gives the same error code just incase something weird didnt happen
    Mar 2006
    Thumbs up cheers
    cheers for all the help
    if it helps i had the motor running perfect in a wagon,
    2 weeks later i pulled it out and swapped em over with the manual box
    got it running and 1 of the headers wasnt sealing properly
    tightened it up
    then next thing i know i start it and look at the dash and the light was on
    would a series 1 knock sensor fit in series 2engine?
    Thanks again for all the help
    ive got a spare series 1 i might have to grab it off
    nowonder i noticibly lost torque
    Mar 2006
    i just got back from repco
    it was i think $93 for a vp v6 knock sensor
    so thats sweet as
    does the old one just unbolt using a ringspanner?
    I ACTUALLY MEANT CODE 43 KNOCK SENSOR
  1. HSV Knock Sensor in VN
    By griffindore in forum V8 Development and Modification
    Last Post: 23-11-2011, 12:02 PM
  2. knock sensor?!?!
    By sillybilly205 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2011, 05:09 AM
  3. Knock sensor....
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2007, 06:32 PM
  4. vr v8 knock sensor
    By redvngroupa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2005, 11:47 AM
  5. 5L Knock Sensor
    By v8maniac in forum Electrical Wiring / Questions
    Last Post: 28-04-2004, 05:48 PM
