Results 1 to 5 of 5
Thread: cutting out
    StatOmaN's Avatar
    StatOmaN is offline Custom Title
    Vr Statesman
    Aug 2005
    Bangalow
    Default cutting out
    hi all just postin up a q for a mate, hes got a vn v6 and it keeps stalling/cutting out when driving, changinf from P into gear and after reving it. did a error check and came up with
    Code 34 - Manifold Absolute Pressure Sensor (MAP) - Voltage Too Low
    could this be the cause of it
    vn hsv sv 89
    Apr 2006
    Double check that code make sure it was the only one, my mates v6 did that when the crank angle sensor died, I can't see a map sensor causing that.
    StatOmaN's Avatar
    Vr Statesman
    Aug 2005
    Bangalow
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    map will cause the car to run rough as guts, so replace it, even from a wrecker if it costs to much from holden, also get throttle body cleaned.. cheers fitzy
    My00 Wrx 240kwatw
    Apr 2005
    theres one on ebay..
    looks good to me
    http://cgi.ebay.com.au/VN-to-VR-MAP-...QQcmdZViewItem
  1. VN V6 cutting out
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2009, 04:35 PM
  2. VP Air Con cutting out
    By VP-Matty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-06-2008, 10:18 AM
  3. Amp keeps cutting out?? PLS HELP
    By Holdenboy_VS in forum Car Audio
    Last Post: 17-01-2007, 10:57 PM
  4. Amp cutting out!!
    By donz in forum Car Audio
    Last Post: 01-11-2006, 08:37 AM
  5. VX a/c cutting out
    By VX_GIANTZ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-10-2005, 10:24 PM
