Results 1 to 7 of 7
Thread: front strut shudder...
    vn berlina s1 5.0L
    Jan 2005
    Default front strut shudder...
    i had some work done today, i had to have the rubbers which sit atop the bearing plates of both struts replaced. i also got a wheel alignment done.
    apart from costing me over $350 for 2 bits of rubber and a wheel alignment, the passenger strut now shudders every time i turn left, enough to make me slow down if i'm going around a bend.
    a) did i get ripped off?
    b) it's not just new rubbers needing to wear in? have they stuffed something up?
    vn hsv sv 89
    Apr 2006
    I've had suspension replaced and never had any of that, you should definately take it back.
    VP Executive R-spec
    Jan 2005
    Somethings stuffed, Luke had a technical problem with his, the top spring seat needs to have the little notch on the edge of it facing towards the wheel. Check that
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    take it back tomorrow, tell them what you told us, they *should* take it for a drive around the block to test and fix the problem, as im assuming it only started after the new bits.
    vn berlina s1 5.0L
    Jan 2005
    Quote Originally Posted by hakhawk
    took it back. apparently the seals on the end of the steering rack are worn and are letting air into the power steering lines. quoted $500+ for a fix.
    apparently it started after the work was done because the car is sitting differently on the road and the load on the power steering is different.
    i'm a bit skeptical... i'll get a second opinion on the weekend.
    hakhawk's Avatar
    Jan 2005
    if its the seals on the rack and they want 500 to fix it, you could pick up a reco rack for a couple hundred i would imagine, put it in yourself.
    second opinion is the go.
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    $80 from the wreckers, Sounds like a plan... Do it yourself! Dont pay anyone for anything you can do yourself.
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
  1. Front Wheel Wobble Car Shudder Help
    By jolea682 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-11-2006, 10:17 AM
  2. Has anyone brought Front strut bar
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-06-2006, 12:22 AM
  3. Front end shudder at speed
    By Pretender in forum General
    Last Post: 28-10-2005, 08:57 PM
  4. front shudder
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2004, 08:47 PM
  5. Front Strut Removal
    By Spinksy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2004, 08:01 AM
