Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: how to shave an paint a dash
    VL Berlina 5speed turbo
    Apr 2006
    Default how to shave an paint a dash
    hey guys im not sure if this has been done here befor but i thought i would list what i have done to shave out my ash tray an ciggaret lighter an the line around the shifter in my VN auto,
    1, i sanded everything with wet an dry the whole lot because it is going to have to be apinted,
    2,get the car putty ready, this is the first time i had used putty an was a bit weird but i did some practice runs on bits of old wood first
    3, i then applied it all around the line or "groove" around the shifter an ash tray an ciggaret lighter, i built it up so i can sand done latter with a more harsh one at first then a smooth one when im almost done sanding
    4, then i to fill in the ash tray i applied a larger amount over the whole area an smoothed out with a little grout tool for tilling,
    5, i then did the same thing to ciggaret lighter,
    6, i should have done this bit first, i used a ruler to cover up the whole where the ash tray was an ciggaret lighter im sure you could use any other sorta of hard plastic to do this then i glued it in with araldite(sorry carn't spell) you could use any other sort of plastic i guess but since this was my first time doing this sort of stuff i tested all the bits of plastic with the putty an the primer i will be using just to see if it will eat it or not i guess it pays to check incase you start an it eats everything,
    i will post more later today an pictures tomorrow,
    i hope this has helped some people an have some fun like im doing with it
    VN Wagon,
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Ill post pics of mine later (have to go get batteries). I painted the cluster surround, stereo surround (bogged up the bottons), shifter surround, center console (including bin lid).
    AirStrike
    Selling FG G6E Turbo and buying a N/A Supra
    Apr 2006
    ahh thats sound good,
    ive almost got there in sanding it back, an i used a bit of a more course sanding paper to start of with, an it had taken a few chunks out of the bog, so lucky ive got this spray bog that my brother had used on he's truck an it works great for little holes like that so i will use that this afternoon to make it so it's all smooth like a babies bum, because a little hole like that would drive me up the wall cause i know it is there
    VN Wagon,
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Heres all mine.
    AirStrike
    Attached Thumbnails Attached Thumbnails how to shave an paint a dash-img_0810-small-.jpg   how to shave an paint a dash-img_0812-small-.jpg   how to shave an paint a dash-img_0813-small-.jpg
    VP WAGON V6
    Mar 2006
    im in the process of doing all mine. Im doing around the handbrake, the gearshift the same as your talking with the ash try and cig lighter then im putting a heap of buttons there and lights and stuff. Ill put some pics up when im doing. I also did the stero seround much like airstrike did but i have put my 2 inch gauges into the bottom setion of it and i MIGHT have to change it again when i get a dvd screen. I also took the lines out of the aircon bit.. the lines above and below the speed selecter. Im also doing them white cause my car is white. Its coming along quite nicely gotta get stuck into finishing it tomorrow though i need my car back together
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by commy92
    Thats how my stage 2 is. I did it like that orginally but some of the bog cracked so I did it fairly standard just painted for now.
    AirStrike
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    Apr 2006
    hey mate,
    just doing the finishing touches tonight
    and i will buy the paint tomorrow, and i will also gets some shots
    ive got heaps to do since my cars of the road for a month or so
    cheers wagonb0y
    VN Wagon,
    Jan 2006
    stanthorpe, qld
    awsome ive sanded mine back im getting the paint tomorrow
    i hope mine turns out alrite
    Adam
    VP WAGON V6
    Mar 2006
    mine is sorta painted. well the radio surround is done. A couple of runs but tahts what happens when you use a dodgey supercheap special spray gun. thankfully there are in places that will be hiden away. The centre conso pieces have to be sanded back again. Stupid pos. And the aircon bit i stuffed up. So anyway i gotta get it all done this weekend hopefully. Get my licence back on friday or something. I was hoping to get it all done by then but i wont. anyways ill post a pic of mine undercoated. like my head unit..
    Attached Thumbnails Attached Thumbnails how to shave an paint a dash-imgp0321-600-x-450-.jpg
    binkztarr's Avatar
    binkztarr is offline 2DA-PUB
    VN Ex Cop
    Jun 2006
    gawler sa
    Jan 2006
    stanthorpe, qld
    hey commy92 & binkztarr they look pretty good
    im painting the glovebox, fuse cover, stereo surround and the side of the center console.
    here are some pics of it all riped out and the top of the center console painted
    Adam
    Apr 2006
    Looking good mate
    i carnt wait to finish mine of tomrrow
    cheers wagonb0y
    VN Wagon,
    Jan 2006
    stanthorpe, qld
    i have a question!!!
    do you need plastic primer?
    i painted the center console without it and its fine for now.
    the reason i ask is everywhere in this sh!thole town doesnt have any
    one place looked at me like i didnt know what i was talking about
    Adam
  15. #15
    binkztarr's Avatar
    VN Ex Cop
    Jun 2006
    gawler sa
    its probably better to use it but u woodnt need it,
    i used actual car paint on mine which is why it came up like.. well "car paint"
  16. #16
    Apr 2006
    I have no idea mate sorry.
    i just used one pac primer then put the spray putty over there was few little marks ect and i just layed the first coat down about an hour ago,
    hope this help
    wagonb0y
    VN Wagon,
  17. #17
    Jan 2006
    stanthorpe, qld
    Quote Originally Posted by binkztarr
    what do you mean by car paint?
    i bought this stuff today
    i got superglow thiners
    quick drying spray enamel (same sort of paint i used on center console)
    top coat clear
    it was a sh!tty day today so i couldnt paint and i wasnt sure if i needed plastic primer
    Adam
  18. #18
    VP WAGON V6
    Mar 2006
    im just doing it as if i was painting a car. I basically sanded, bogged, gued some timber on bogged some more. sanded some more shapped with a grinder and file and stuff. Then did a final bog snded back, spray bog and double check it was all smooth had to do a small touch up with bog. then undercoated with normal car undercoat wet and dryed back with 600 then 1200 then lots of coats of white car acrylic. I gotta sand it back with 1200grit wet and dry then get a holden sticker to stick on it then LOTS of coats of clear. Im think about 10... That way it will never scratch.... he he he
  19. #19
    38VNIT's Avatar
    38VNIT is offline Azerium
    nothing
    Jul 2006
    Inverell
    For my dash, i am currently redoing the door apolstry, and am planning on getting the whole dash painted with a clear/black, to darken it heaps but it sill still be grey, and am choosing weither to do green or pink for my interior, ill prolly go green tho, more aftermarket stuff is available in green
  20. #20
    NVE_069's Avatar
    NVE_069 is offline Vx Calais / Ve Berlina
    Vx Calais LS1 / Ve Berlina V6
    Mar 2005
    thay look mad i think some of u should make em and sell them lol id buy commy92's one ????? lol
    cheers
  21. #21
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    wont using bog on the shifter surround cause it to crack if it ever gets removed later as you have to flex it and why hasnt any1 tried a flake or metalic paint instead of plain colours
    im not admiring your car im looking in disgust
  22. #22
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by HDT_aero
    Why hasnt anyone tried a flake or metallic............cost. As it is, its not the cheapest thing to do once you add up the sandpaper, bog, applicator, plastic primer, white primer, top coat colour, top coat clear, masking tape, etc ,etc.
    AirStrike
  23. #23
    Keesh's Avatar
    Keesh is offline WATSON HOLDEN
    VQ 5L Caprice, WH LS1 Statesman, VN 5L Calais
    Jan 2006
    i dint sand ne ov mine down, now im thinkin i should have haha.. just dont use any ov the K&H paint it is the worste, stick to vht it works the treat, if u get time look at interior pics and u will see my vn with the white interior
    good luck
    Don't blame me, It's that damn percadan..
    If you ask me, that stuff rots your brain...
    And now a word from our new sponsor.. Percadan? oh crap!
  24. #24
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    When i was asking about painting parts of my interior the guy told me to undercoat, the use a Vinyl paint because it wont chip or come off?. Any truth in this he was a paint guy
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  25. #25
    Keesh's Avatar
    Jan 2006
    undercoat of what? as far as the dash goes, the paint has stuck, as for the doors haha thats a different story.. using black VHT on the doors worked well, using white on the doors was a mistake. everyday i find a new flaky spot, i used alot of K&H white vynil PAINT on the doors and it flaked, im going to sand bak or peel what i can and paint them with the VHT vynal dye which was my original plan but autobarn ran out ov it so my impatience forced me onto the K&H.. on plastic like the window pillars and glove box the K&H works fine, on vynal stick to dye.. black works well on everything i just think that the white isnt very good
  1. What colour to paint the needles in the dash?
    By H00LiGaN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-03-2010, 04:21 PM
  2. Replies: 10
    Last Post: 13-09-2006, 11:24 PM
  3. Touch up paint for metallic paint jobs + Rust sub-question.
    By down_with_the_system in forum General
    Last Post: 24-04-2006, 10:19 PM
  4. Replies: 2
    Last Post: 02-11-2005, 07:10 AM
  5. how to paint the dash
    By tgolds1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-10-2005, 11:15 PM
