Results 1 to 18 of 18
Thread: strut brace
    vn 5ltr + bt1 pack
    Dec 2005
    YOUNG N.S.W.
    Angry strut brace
    :b: My 4 month old strutt brace has snaped what do you reackon might cause this as it wasnt cheap nearly$200strut brace-000_1001.jpg
    I didn't do it
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    well it only look liek aluminium mounts to me so maybe get some made up out of stainless or mild steel cos you wont get warranty for it cos you installed it so its your fault for not setting it up correctly..... thats exactly what the seller is going to say
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Looks like a fairly shitty construciton for $200.... what brand? I hope it isnt whiteline cos i was thinking about getting one of those. As its just the strut plates, can you get some machined to weld back on? The metal looks ot thin to take the stress of both mounts for a long itme in a 5ltr.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    vl berlina,vl nothing,vt v8 ex police
    Aug 2005
    perth WA
    missus (in more ways than one)
    Sep 2005
    look, most strut braces ive seen have the plate with 3 bolts, so 2 has a look of weekness, and now doubt you thrash this a little bit??? cause a little bit of flex and snap. you have 3 options now dude, wither
    1 . take the whole lot off, and weld the plate back together (if you dont have or know someone that can weld, go to a genral enginnering or sheetmetal place) and get the to grind all egdes on an anlg eand reweld, it will come up nice (10-30 bucks)
    2. go to a genral enginnering joint with a drawing and get them to make you up new brackets (a bit more costly)
    3. buy a new strut brace
    personally, i would take option 1, as it will clean up nice with a good pre greind, and nice deep penatrating weld, and a good clean up grind
    Sep 2005
    oh and as for the cause mabye your engine mounts are a tad loose and the motor was rocking a bit, pulling one strut tower up a lot more than the other, or just a good chassis bend, like a quick sharp jolt of a corner
    Boonz's Avatar
    Jul 2005
    or maybe cos its aluminium its not suitable for highly stressed applications....
    Sep 2005
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Ah it doesnt look at strong enough...metal is quite thin in places...just like the ones on Ebay.. Theres alot out there that just dont appear to be thick enough or strong enough?
    I would go back and complain where it was bought...
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    Excuse my ignorance, but what exactly does the strut brace do? Braces struts I suppose.
    VN 5 spd/VR Calais daily driver
    Mar 2006
    NZ
    Quote Originally Posted by fazz1977
    Lol you're right.
    Stops flex between the strut towers during cornering which gives you better handling. Basicly the stiffer you can make the chassis, the better it will handle (assuming it's not substantially heavier ofcourse).
    fazz1977's Avatar
    Aug 2005
    vn 5ltr + bt1 pack
    Dec 2005
    YOUNG N.S.W.
    Its made by nolathane. I just found that one of my stabliser pins is loose up top and has worn thin do you think this would have helped it to break. as for what next my uncle works for national engineering and should be able to tig it for me and maybe make it stronger
    Uncle has had a look It's steel but he reackons he can make a stronger one from scratch
    I didn't do it
    Boonz's Avatar
    Jul 2005
    well thats handy make it out of stainless steel as it doesnt get weak spots when it is welded
  15. #15
    flipsyde Guest
    HAHAHAHA
  16. #16
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by flipsyde
    HAHAHAHA
    wtf... unless I am missing something here.....that aint cool man
  17. #17
    vn 5ltr + bt1 pack
    Dec 2005
    YOUNG N.S.W.
    anton1o's Avatar
    anton1o is offline [GMHVN6]
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    That looks poorly made, and why you would buy something like that astounds me..
    As you can see its only using the 2 bolts of your Strut tower.. 99% of braces will use all 3..
    I wouldnt blame that its cause its a 5ltr or cause you throw your car around.. As 2 of my freinds are using the type sold on ebay and compete in Toyo Drift.
  1. strut brace
    By vz 914 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-09-2008, 07:25 AM
  2. Strut Brace ....
    By sobvngrpa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2006, 11:07 PM
  3. GMH Strut Brace
    By vxcalais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2006, 09:13 PM
  4. strut brace
    By tgolds1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-08-2005, 11:24 AM
  5. Strut Brace
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2005, 12:54 AM
