ok well under direction from foamy.. ive greated a thread so everone out there in the knowledgable world of JC, can either help me, hinder me or inturn help them... he he he..
Well anyway i have no idea where to start i know i have to play with spark and advancing it a bit then get the fuel mix rite. Not sure what else.
My car has got a pod filter, CAI, 70mm tb, 2.5inch cat back.. high flow cat running 1 muffler.
Ive downloaded Tunerpro and the bin data for the vn and the ecu data for a vn. I just hope that this information is the same for a vn and vp.
I think thats all for now so if anyone can help me ide love you for ever.. lol
Michael
It's probably better to start with the VR binary really, it's a much better thing, more complex yes but better.
Here's the ECU file and the Manual VR binary you use as a base to convert back to a VN-VP tune
Also Below is the VS V8 Manual tune, BWFW
Here's something for you all to do today.
First lesson in converting a VR V6 manual binary to run on a VN/VP V6 Auto
(I'll adjust the above post to include a V8 base binary tomorrow)
KOPTFLG4: Option Word 4 - Bit 0 - Bit 0
Bit 0 1 = Disable anti-theft module control
In the flags and switches section you will find option word 4, now bit 0 turns the VR anti theft on or off. We want to disable it so the car will start!, so double click bit 0.
To set word 4 bit 0 to a 1(anti theft disabled) we need to click the little box shown here and then push save (and then saveAS your binary)
Congratulations, the VR tune will now start your VN or VP, wooohooo
Ok now for the next part
KSPDSENA: Road speed params - Speed sensor constant Pulses/Kilometre
Another thing we have to fix is the way the ECU reads the speed sensor.
In the VN and VP the speed sensor runs into the cluster and gets divided by 5 then sent to the ecu.
In the VR the speed sensor is wired straight to the ECU so the value in the VR is 5 times higher,
but problem is we are sticking this in a car that is wired up VN style so we need to fix this
and tell the ECU that the pulses per km will be 5 times less than it expected from the VR.
So find KSPDSENA in the Constants section and double click that.
Now here we can see the stock VR pulses per kilometer 6248.14, scrub that
And enter the VN spec version1250.05 and save it
YaY, now all our speed related code in the VR tune will work things at the proper speeds
You could now drive this tune around kinda..... but there's one more important thing we need to fix.
KTCCTMPL: TCC lower temperature limit
Double click this
Here you see something interesting!, even though this is a manual tune it does retain all the code that's needed
to run the VN's auto! amazing and thank you very much Holdenbut they did set this temp to enable the TCC converter lockup too high, but we like it to lock up, so lets fix that.
Set it to 44 degrees and push save (much better!)
LESSON ONE COMPLETE
I hope everyone learned something and yes this thread will be something special so might as well sticky it right nowbefore we go much further into making the old VN/VP, smoother, faster, and more fuel efficient
, I'll even get into the tuning for boosted cars with 2 bar sensors later on
such a helpful chap foammy
Thanks so much greeny. I new you would help me out.. Ill get to making my thingo in abuot 5 minutes.. lol
hey greeny the vr ecu file isnt there
Yes it is, it's in the first zip file it's .xdf for the newer tunerprosOriginally Posted by commy92
dont you need a .ecu file as well???
ok sorry bout that i worked it out and did tut1.. lol.. so greeny when does the next stage come???
Hey fella's i got x2VR and x5VN memcal chips i was just wondering if there is anyone out there that reprograme these that would like to do a swap for them.I'm after a performance enhanced chip for my s2vnv6 i see most of these reprogramed performance chips for vn/vp i see on ebay sell for $150.I could be wrong but this seems like a good deal to me as how much you could make once these chips have all been reprogramed.Unless i'm wrong and these memcal chips are a dime a dozern
Send Dr Bob a pm about how many stockies it will take to get you a tune. Then you can delete your post and I can delete this one and I'll continue with the guys that want to learn how to tune their car themself![]()
Foamy,
What would be a good make and place to buy a programmer to burn these chips when i have finished playing around in turnerpro?
cheers,
FXST01
Illegitimi Non Carborundum
this might seem a dumb question but all this is verry interesting to me but how do i go about tuning my vn with this program? do i need to hook my ecu up to my computer?
k§£¥
Sorry fella's for going off topic now that you have told me who to see please delete my post in this thread
Just search for "Willem eprom" on ebay you are looking for one like this, you can put it in a box or just lay it on your desk like I doOriginally Posted by FXST01
http://cgi.ebay.com.au/27C256-Dual-P...QQcmdZViewItem
There are other threads around about how to do it, basically you just want to change the program on the eprom that's in the memcal, you don't need to hook a computer up to the ecu but you can do that if you want to tune it as you drive around, www.moates.net have the bits you need to do that. But yeah search around a bit and you'll find out everything you need to know. If you have an engine that came with a mild tune from the factory and is a good breathing motor ie, the 5 literOriginally Posted by kasey375
you can alot more power and ecconomy very easily. But the V6 will only see small gains, in power at least. Still worth doing though.
As for converting the VR binary to the VN, it will be driveable with what I've posted so far. The air fuel ratio at WOT will be a little rich on most stock cars, closer to correct on a VN with a very good exhaust. I'll add some more changes you can make to get it closer to what you want after tomorrow
going to teach us how to burn as well foamy?
Adam
1990 VN S1 V6 Calais (SOLD!)
1996 Toyota Supra Turbo
Nope, allready done that in an old thread or ten
lol so when does the next step come mate... im hanging here. lool
Just seen this on ebay.
any one no if its any good or know what the info on it means
http://cgi.ebay.com.au/VN-VP-Compute...QQcmdZViewItem
k§£¥
Originally Posted by greenfoam
cheers buddy
Well Greenfoam you are a man full of knowledge keep up the good work.
One Question why do i smell My radiator coolant when i driving for some time?
any more updates greenfoam just got my burner today cant wait
I'm too busy to be teaching everyone one everything every year someone decides to burn a chip but everything you need to know has been posted allready somewhere so it's easy now
