hi, i am going to install a new oxy sensor, i have read somewhere that after instalation car must be started and held at 3000rpm for computer to reset !, is this true or b/s?, thanks.........
Restart the ECU first just pull both leads off the battery for 1-2min or in the time your doing the Oxygen sensor would be best. Then start it up, I'm not sure about the 3000rpm thing.
Originally Posted by Yoda
It says to i the manual i've got. I do it if i disconect the battery, but its a good idea to warm the car up first then disconnect the battery and reconeck it then hold it at 3000rpm for 10 secs
I didn't do it
it doens't matter a whole lot. the ECU will remap itself over time, you won't do any damage either way.
when you put the new o2 sensor in run the car for a bit until the manifold is warm!!
it supposedly makes it easier to get off
Adam
Or just stick a can off wd40 on it that also works
I'm thinking when i do myn I'm going to have trouble getting down there, I'm a big guy i have stuck my body in places man wouldn't but i think my shoulders are a touch to wide to get a good grip in there, Is it changeable underneath at all??
i dont think you could get to it from underneath!!
it is a bit of a mongrel cause you cant get a socket over it cause of the wire
Adam
So just stretch and wrench it offTake off the air intake hose to.
yep strech as far as you can![]()
yea take intake hose off!!
im lucky im skinny and have long arms i can reach nearly everywhere![]()
Adam
For the 3000 rpm thing.. When you reset the computer, holding 3 grand for 10 seconds helps reset the idle air control valve. Usually if you don't do this the car will idle real rough and pour smoke but will probably reset itself next time you drive it anyway.
just did my o2 sensor last night. i found it easier taking the wheel off and going from under the car. i idle mine at 3000rpm for a little bit to reset everythig and it all good now. code 12 all the way
is there any gain from replacing the o2 sensor on a V8, my car has done 300,000km's??
maybe!!Originally Posted by XSS1VE
do a fault test and see what it comes up with.
if it aint broken dont replace it
Adam
I got long arms but I'm not skinny lolOriginally Posted by _A_D_A_M_
I'm only 180cm tall but my arms go 188cm
And they say your height is arms out from hand to hand
My brother changed my oxygen sensor last night, Took him 3min off and on i was shocked, Wont know till Wednesday how the fuel economy is, But first thing noticed i have a slightly sicker car at the moment it's a touch ruff at start ups and holds revs a little. Reset the ECU even did the 3000rpm thing.
Even though it's hard almost out of petrol i think it seems better on fuel, I today went to airport west to wreckers, Good guys there also, Then onto deer park and back home to sunshine, Clocked about 40-50km, Hardly moved a line in that time, And i wasn't pussy footing about.
Can't wait to try a full tank I'll know in the first 100km if it's a improvement 100%.
Yea i changed mine just last week before my dyno run. I was told it wasnt the best condition as i had my comp remapped two weeks prior. Well anyway i gained 12rwkw. It could of been the sensor or just the difference in dynos. Its easier to get to them from under the car. 5 minute job. Alot more economical and a tad smoother. I didnt do any of that reset shit. lol Cant believe how workshops can rip $160 off you just to change it.
My brother stuck his spanner down under the bonnet twist and it was off and the new was on in 3min i was like WTF??? That easy??
But when the old one came off OMG! it was black and charcoal it was D.E.A.D Like 100 years ago it was just shit no wonder i have been struggling with fuel.
I think I'm getting better economy already, I was about 210km when we done it i only get 260km to a full tank, I drove the car 3 days with only adding $10 @ 1.35 per litre and got 348km now i have just filled up and we shall see![]()
Here is the oxygens sensors first full tank. Seems to be doing alright.
how much are the o2 sensors and is thereone or 2 on a v6
hay i got mine for $65.
and there is 1 on the v6, but make sure you get the right 1... coz i think there is a differnce between the series 1 and 2...
Adam
Yes series 1 i think was 1 wire and Series 2 was 2 wires for VNII-VP's. Repco has Bosch for $80-$88
Update of my dashStill doing good mostly 95% is local driving and driving harder then normal cause in the past when i have changed a part i drive like a puss
. Not this time.
you can get a genuine 1 for $80-100.
i got a gbc for my series 1 and it has 1 wire. i think the part number is OS-1037 im not sure but thats what is on the box.
Adam
I went out tonight and just clocked up 280km with it just tipping on the other side of the half needle to the empty side bloody awesome![]()
your lucky you could test yours
Adam
Can't you test yours?
