Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: brown slime in my radiator!
    Vz Sv6
    Jul 2005
    Default brown slime in my radiator!
    hey guys,
    i have some kind of slime in my radiator! i dont no how it has happened or wat it could be but it is brown (due to rusty bits) and has only happened since i flushed my radiator about 2 months back. any suggestions to wat it is and if it is harmful to drive with? i will eventually get a flush done properly when finances are better!
    cheers
    Jezza
    '04 VY SS 5.7 A4, '94 VR 5.0L M5
    Jan 2006
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    It obviously needs to be flushed....are you sure u did it properly 2 months ago?
    Flush it PROPERLY now...it could cause the car to overheat or damage to the radiator
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    the slime is most likely little rusted pieces of your water pump that have been circulating around the cooling system for ages turning them into a nice pastey gunk.
    thats my best bet anyway...i really good flush might fix the problem for a few months, but if it is the water pump nothing will completely get rid of the slime but a new one.
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Same with me flushed it out and it came back.
    Be careful of it dropping on the car as it's a bitch to clean off it stains bad.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    maginoodle's Avatar
    maginoodle is online now Donating Member
    vy series2 ss crewman
    Apr 2006
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    When you changed the coolant did you use those coolant pellets that Holden tell you to use? If so it's probably those. They created little slimey particles that are supposed to keep your water pump lubricated.
    VN S2
    Mar 2006
    I also just found that brownish/green slime in my radiator ,gave the radiator a quick flush but the slime is still hanging around.Not sure what to make of this and do you have to replace the coolant pellets after flushing the radiator?
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    i had it too but was trans fluid getitng into radiator as they share same radiator pin hole between 2 tanks
    check trans dip stick if brown and oily its trans fluid
    looks yukk
    new radiater and trans flush fixed it
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    brown slime usually means oil or auto fluid in the cooling system.its verry common on commodores
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    I get a little, even after a professional flush and fill. Maybe enough to cover the end of my finger over 12 months. Not too bad.
    Life's Grouse in Frankston South!
    PaRaDoX's Avatar
    PaRaDoX is online now boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    VN
    Sep 2006
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by seveprim
    yeah the slim is terrible when mixed with drinks !!!!!! only kidding ...
    i find its not to bad when mixed with vodka
  15. #15
    VN S2
    Mar 2006
    : So does this mean i need a new radiator or can i get the old one repaired,not that it's that old ,looks pretty new.
  16. #16
    VN Calais
    Feb 2006
    GolD Coast
    Just replace the muffler and it should fix the problem
    I was having an argument with my missus and she said "You don't even know what love is!"
    "Sure i do, its that white stuff."
    Check it out!
  17. #17
    cohn's Avatar
    cohn is offline VN28CN
    VN Calais Turbo
    Nov 2004
    Penrith
    if you are finding a strawberry milkshake in the transmission or radiator, then its the transmission cooler in the radiator, it is easier to ahve a reconditioned readiator put in the ot repair it.
    If you are finding a chocolate milkshake in your radiator or engine oil, then that means the head gasket or valley gaskets are starting to leak, for your sake, you want it to be the valley gaskets.
    Then again if its a broweny orange colour, it could also just be rust built up in the sustem due to poor mantainance, but if a flush doesn' t get rid of it, keeps comming back then its probaly a gasket.
    Soon to be back on the road, Turbo VG.
  18. #18
    VN S2
    Mar 2006
    VN 91- Executive S/Wagon, VN 90 S/Wagon
    Sep 2005
    hey im getting a similar situation
    im getting sludgy mess comming from the plastic part where i add the water?
    its like a dark green to brown sludge.
    it wouldnt be my gasket?
    my dad had the same problem with his ea not so long ago, dont tell me mines caught it as well
    I'm going nowhere
    Where I am it is a lot of fun
    They're in the desert to dismantle an atomic bomb
  20. #20
    VT Berlina & mazda 2 DE
    Jul 2006
  21. #21
    VN SII And VQ SII
    Sep 2005
    Melbourne VIC
    99% chance it's your Valley cover gaskets, its a pretty quick fix and most of you should be able to do it yourselves. if there isn't to much oil in there (and you will know if it's oil by rubbing it between your fingers.) then the problem isn't to urgent, but as soon as it starts to get bad it becomes urgent, due to the reduced efficiency of the cooling system, Also don't do any long trips with it like this (>1.5 hrs/150+km) without fixing it; i've seen too mnay commy's on the back of tilt trays because of this.
    Please PM me if you know of any L67's complete with loom and ECU are for sale
  22. #22
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    if it's the trans cooler in the radiator that leaking just fit an aftermarket trans cooler kit and bypass the original, it's prabably better for your tranny as well. just remember to cap the 2 pipes for the original so that it's sealed incase the radiator starts leaking into it and you loose coolant. if you suspect the it's the intake valley gaskets try tighning all the intake manifold bolts a little
    Body by Holden, Soul by Brock
    the Legend will live forever
  23. #23
    anton1o's Avatar
    anton1o is offline [GMHVN6]
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    Yeah i seem to have this Slime too, its not visible when looking at the water.. But if you poke your finger down and bring it up its there..
    Also i had a puddle of water and i put it in there and it went to that similar oily look around the slime?
    My radiator is fairly new aswell 1yr old..
    ride; [GMHVN6] Project Streeter - VN Berlina '90 mods; 65mm throttle-body / Cold Air Intake / 8mm Ignition Leads / Exhaust
    future; Extractors , Cam currently; 101.2rwkw mission; 110rwkw
  24. #24
    Jul 2006
    Actually that's interesting- mine's heaps bad, when I pull up the yellow dipstick from the spew bottle (overflow) it looks like a baby took a dump in there. But, she just doesnt get anywhere even near hot. Even sitting in traffic in summer- i have yet to see the temp rise. Maybe mine's something else- i'll have to start checking some stuff
    valley gasket- should only take an hour to get to wouldn't it? probably what, $30 or so for the gasket?
  25. #25
    VN S2
    Mar 2006
    Ok ,i took my vn down to local garage and got the mechanic to have a look ..after doing a few checks and topping up the tranny fluid which was low he's certain it's tranny fluid in the radiator causing the oily slime.I'm bloody glad it's not the heads as i got a couple of quotes from differant places and they said around $1200
  1. VN89 Brown Interior
    By HÝPÕ-5L in forum Swap / Wanted to Buy / Trade
    Last Post: 18-09-2007, 11:15 AM
  2. Brown Jelly
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-03-2007, 05:41 PM
  3. Brown deposits inside radiator
    By Famine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2006, 06:49 PM
  4. brown vk
    By jamiekratin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-02-2006, 10:54 AM
  5. wats brown and sticky
    By SENATOR5.7 in forum Jokes/Humour
    Last Post: 24-04-2005, 02:05 AM
