guys need some help which wire can i put the tacho illumination to behind the dash i know its the park light illuminaton wire but i dunno wat wire it can someone hel;p me by telling me a spot toi hook it to
just find a light and splice into it. Say one of those little lights that goto like the gear selceter and stuff like that. Or be difficult and wiring into the fuse box.
Have a look at the back of the cluster when you pull it out. If you look hard you'll see a table describing what each input wire is. Find one for the dash lights, work out the numbering system and you're away. Just tap into the corresponding wire leading to the cluster. You'll see what I mean when you've got it out.
Go to the Audio section there is a wire for illumination there "brown n white" by memory.... hook it up to that if u cant find one behind dash facia.....
