Results 1 to 10 of 10
Thread: Mega Urgent Problem: Auto Stalling Hardcore
    VN Executive
    May 2005
    Exclamation Mega Urgent Problem: Auto Stalling Hardcore
    Hello guys, i have a mega problem. My VN exec auto keeps stalling, when overtaking, when crossing intersections, when on the highway ALL THE TIME. AND LAST NIGHT ALMOST KILLED ME! I was overtaking a bus on the wrong side of the road and ended up stalling and rolled past it just before a herd of oncoming cars. A forklift mechanic at work mentioned it may be a petrol filter problem... So i replaced that and it still happens. Then I was told it may be bad petrol, so i put high octane and it still does it! It tends to happen ALOT more when i am giving it some, but even after i stop, just keeps stalling. And even when driving sensible. CAN SOMEONE PLEASE HELP. Usually before it happens the engine hazard light comes on.
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    your idle air control valve might not be working so when you take your foot off the throttle it chokes the engine of air and stalls???
    VN Executive
    May 2005
    Boonz's Avatar
    Jul 2005
    well do you have to have your foot on the throttle at startup??? does it idle??
    VN Executive
    May 2005
    the car can idle, but often just stops. And when it does idle it aint smooth. When I startup i dont use the pedal at all. Just a turn of the key.
    Boonz's Avatar
    Jul 2005
    how about when you stab the throttle and take your foot off straight away??
    VN Executive
    May 2005
    Hmm from memory I believe that happens alot of the time. But also alot of the time it does whilst throttling
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    If the engine light is coming on, then I'd suggest that you check the fault code that is being logged. There are how-to instructions almost everywhere, have a bit of a search.
    Might be a coil pack playing up, might be leads, might be IACV...check the codes.
    Gravity is proof that nature keeps getting us down.
    VN Executive
    May 2005
    Quote Originally Posted by mouce
    Will do, Thanks mate
    VN Executive
    May 2005
    I have found the problem. There was not enough air to fuel. I was at work comparing my engine to a mate who has the rough idling problem aswell and noticed that my air intake was still the wack old one from the gas. It has a big drum looking thing in it half way which is the air mixture something, then we noticed on the bit of pipe between the air mixture thing and the engine was a stubie holder type thing, and when we pulled that back there is 3 big ass holes drilled in it! I dont understand what its for but i covered it with duct tape and am just fiddling with the ammount of air going through the air mixture thing with the adjustment screw on it. Im not definate this is the problem and that im fixing it but its a start so if you have any suggestion please tell me.
    Also off the topic, if your VN didnt have rear speakers stock, where would I find the wires for them. Thanks
  1. HELP, my AUTO VT is Stalling!!
    By Liddz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-11-2010, 07:37 PM
  2. The Window Tint ULTRA MEGA MEGA THREAD!!!
    By VXWAGMAN in forum General
    Last Post: 16-06-2008, 10:27 AM
  3. VN auto stalling :(
    By -VnExEc- in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-08-2006, 07:01 AM
  4. VR Auto Stalling
    By sicko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2006, 03:35 PM
  5. Auto is Stalling Q?
    By habro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-04-2006, 01:12 AM
