does anyone know if the cluster from a VS will have the same connections as the one in my VN
If you want to plug it into your VN it isnt a straight swap, the VR/VS cluster require some modification to fit. It is achievable, but its not as easy as take the old one out, put the new one is. Have a search thorugh the search function, im sure its been said before
yep, like Doctor Sodways's just said. Im also told that if you just swap them over you'll end up frying ya wires cos they weren't meant ta fit. Will look gr8 if ya do it prop
As said, DON'T put a VR/S cluster anywhere near your car without the proper mods.
Why do you want a VS one?
Originally Posted by davway
i recently put a calais l3 dash in my vn, i was lucky enough to have the trip computer plug already there behind the dash, otherwise you gotta mod the loom a bit, plenty of info about it here thou
from what ive read puttin in a vr/vs cluster results in fire and smoke
isnt the l3 cluster the same look right thru anyway> so why not just put a vn/vp l3 in?
