+ Reply to Thread
Results 1 to 10 of 10
Thread: VN Speedometer
    VN Commodore Wagon
    Jun 2006
    Default VN Speedometer
    Hi, i have a small problem, i was travelling on the highway today and noticed my Speedometer was not going any higher then 80km/h
    any ideas what the problem could be?
    Thanks in advance for your help
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    VN Commodore Wagon
    Jun 2006
    hey, well it just happened today. It seems to be workign okay now, i just had to give it a tap:P i think the cogs or something musnt have been flush or something, but its fine now.....will post if it f***'s up again, and cant fix it
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    no cogs in the speedo just in the odo fars as i know may be wrong tho. a speedo is just a big volt meter(or ammeter)
    Nov 2004
    Gday mate
    i got the same problem last week and its happening every few days
    but if you tap it it goes away
    CALAISIX Guest
    Hi Guys... I have a VN Calais 89 and have a similar problem. My speedo needle gets stuck down at 0 quite regularly. Sometimes when i hit 60km/h it flies up and works fine again. Seems that once i stop and needle returns to 0 it sticks again. I have to tap down on the top of the dash just above the speedo to get it moving. Seems to be around 10km/h out also. I set my "over speed limiter" to 70km/h and the needle shows around 80ish or just over before the warning light flashes for 70km/h. I'm assuming the light is showing the correct speed coz i use it all the time and haven't had and speeding tickets since purchasing the car and use the "OSL" regularly.
    How easy is this to fix??? Is it costly?? i don't really have any knowledge on repairing these matters.
    any suggestions would be appreciated.
    not a huge issue...sometimes it's better not knowing how fast your doing.lol
    hakhawk's Avatar
    hakhawk is online now forum adjudicator hakhawk Grange hakhawk Grange hakhawk Grange
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    could be the typical dirty contacts in the back of the cluster, take it out, give them a clean, make sure nothings broken. see how it goes.
    missus (in more ways than one)
    Sep 2005
    i tend to crank my system up and put the bass up ridiculisly loud for a minute or so when i start driving, really frees up cluster, other than that your palm is the next best thing
    hakhawk's Avatar
    Jan 2005
    CALAISIX Guest
    MMMM sub bass. Good for many things!! I'll have to stick to smackin the dash till i either get some subs or have a chance to pull things apart and investigate. (don't really wanna start pulling things apart coz when i do, they seem to stay apart)
    cheers for the advice!
+ Reply to Thread
  1. Ask the Speedometer repair guy..........
    By speedotom in forum The Pub
    Last Post: 14-09-2011, 05:57 PM
  2. Speedometer Signal
    By jake_au in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-04-2009, 06:17 PM
  3. speedometer sticking
    By hcvr1994 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2007, 09:27 PM
  4. Speedometer Not Working
    By Aussie_Watto in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-08-2005, 05:32 PM
  5. Im lookin for a speedometer gauge
    By djay86 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-08-2005, 06:09 PM
