Results 1 to 9 of 9
Thread: Removing rear trim from VN wagon
    crazyspoon05's Avatar
    crazyspoon05 is offline Penguin Whisperer
    The 'Bizta' VNVPVR Wagz
    May 2006
    Default Removing rear trim from VN wagon
    Hi all
    Just replaced the roof lining on the wagon this week but in the process cracked part of the rear trim on the wagon, one side came off ago but the other side cracked as soon as any pressure was placed on it.
    I'm going down to the wreckers to try and find some decent trim bits for the rear but are there any tips in removing the trim without it breaking as it seems really brittle...
    Thanks in advance
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    nah sorry mate i broke my brothers trim
    it is 16yo so it would be very brittle
    Adam
    kowan's Avatar
    kowan is offline Clayton's Commodore
    91 Clayton's Commodore/Toyota Lexcen
    Sep 2005
    Far North QLD
    I broke mine too...but there has to be a better way to remove it.
    I will be watching this forum for the answer.
    http://aussiewholesalers.com now closed When I growup I`m gunna buy a real car
    VP WAGON V6
    Mar 2006
    May 2006
    Looks like I'll be doing an experiment on all the wagons at the wreckers to get the answer to the easiest way
    VP WAGON V6
    Mar 2006
    he he flog me one of the pieces that goes accross the back on the hood lining.. Or atleast some clips... lol
    Madhouse_Dave's Avatar
    Madhouse_Dave is offline Crazy but Happy
    Vt Berlina Sedan & VT Excutive Wagon
    May 2005
    Cool Head Lining and Plastic strip success
    Hi All
    I replaced the head lining in the Old VP wagon the other week with
    the Mrs helping we removed and replaced every piece with no breaks.
    I used a long screw driver the longest I could get. You know the really
    ones in the screw driver kits from Kmart. the Stanley ones its a square
    sharfted type. anyway I lifted one side a little and then moved the driver to the
    other side lifting it gentley as I went. To our surprise nothing went wrong
    and I mean nothing with the strips. The only thing that I wasnt happy with
    was the head lining I got had 4 plastic plates 2 under the rear handles
    and 2 in the rear cargo area. I had to put them in and the bolts I had
    didnt fit so the plates are floating around in the car now.
    All in all a very happy day to get it done. All thanks to the
    advice and pictures posted in the JC how to. What can I say
    this is a great group.
    I've Got Papers To Prove I'm Sane.
    Can You Produce Some Too ???
    Madhouse_Dave
    May 2006
    Thanks Madhouse Dave, I'll add that to my list of 'experiments' for the wreckers next week....
    Must say though that you and your missus obviously have a lot more patience than the rest of us here !!!
    May 2006
    Ok, went down to the self serve wreckers Tuesday and got myself a pair of new rear trims for the cargo area of the wagon but unfortunately the only answer I came up with is some trims obviously age worse than others as the first one I pulled off a car came off perfectly but otherside snapped in half far too easily
    Then I spent a while trying to find another decent matching one for the otherside (ten VN-VP wagons in the yard, all ten had at least one side of the trim broken so ended up going for one a slightly different shade of grey)
    I did go from the middle plug out though, holding my palm above the trim so it didn't rise enough to crack, managed to put a couple of small hairline cracks in one side putting it in though.
    Only other thing of course was I had to cut the trim under where the seatbelts go through to get the belts back under the trim, but you can barely notice it unless you look hard at it...
    Attached Thumbnails Attached Thumbnails Removing rear trim from VN wagon-leftsideold.jpg   Removing rear trim from VN wagon-leftsidenew.jpg   Removing rear trim from VN wagon-rightsideold.jpg   Removing rear trim from VN wagon-rightsidenew.jpg
  1. HELP! Removing VR exterior trim
    By Summer-Sickness in forum General
    Last Post: 19-02-2007, 07:54 PM
  2. Rear door trim for wagon - sedan the same??
    By mad13b in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-01-2007, 08:58 PM
  3. Help for removing rear door trim & tips on parint touch ups please
    By lobedowg in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2005, 02:04 PM
  4. Removing rear 1/4 gutter trim
    By Bec in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2004, 11:41 PM
  5. Removing Gutter/rear 1/4 Window Trim
    By OSL-060 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2004, 07:43 PM
