Results 1 to 6 of 6
Thread: Help with Late Brake lights
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Default Help with Late Brake lights
    I was told the way to solve my late brake lights turning on was to change my brake light switch. As it took a very long press to light up the brake lights.
    So today i got the switch and the old one was very hard to remove, But i got it off and installed the new one, To my shock nothing had changed for the better, In-fact it now is worse then before it takes even more brake to light the brake lights up.
    Does anyone know how to make the brake lights come on without pressing hard on the brake as it's made me a very late braker to make sure they come on when someone is behind me.
    Can it be adjusted at all??
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    How far into the bracket did you push the new switch? It only needs to touch the brake pedal slighty so that the lights are off, the switch doesnt need to be completely in.
    Illegitimi Non Carborundum
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    About the same as the old one till it stopped turning.
    VN series II custom :) and VZ exec
    May 2005
    Mildura
    back the switch off a little, screw it out, and get another person to check lights, just keep unscrewing and pushing the brake pedal slowly and see when the come on, when your happ do up the plastic nut, pretty sure thats how you do it, havent done one for a while.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I was cheesed off bad i just got the VN Calais taillight looms and they looked great much brighter with all 4 lights.
    I can probably do it at night if no-one is home back up to the fence.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I done it i loosen the switch and it now works very fast, But as is my luck with this car as a smile i then loose that smile, While checking the parcel shelf brake light it snapped in it i have alot of them smile loose smile with this car
    Anyway thanks for all the advice it done the job perfect thank you.
  1. no brake lights
    By munchie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-04-2008, 12:58 PM
  2. no brake lights
    By invasion in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-05-2006, 06:51 PM
  3. Brake lights
    By Vp1992 in forum Electrical Wiring / Questions
    Last Post: 05-05-2005, 04:52 PM
  4. Brake Lights 2
    By thespiceweasel in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-02-2004, 06:19 PM
  5. Brake Lights
    By ssilent11 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2004, 08:22 PM
