Results 1 to 4 of 4
Thread: just learning
    just learning Guest
    Default just learning
    I've just brought a 88 VN and can hear a rubbing noise in the motor It sounds like the wheel that turns the fan belt is rubbing. Can anyone tell me what he thinks it is and if it's serious
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    It could be the bearing in the tensioner pulley, mine makes a slight noise but my mechanic said it was fine. There's a few things that run off that belt, water pump, alternator, power steering pump, AC compressor. I'd suggest getting a mechanic to take a listen and see what he thinks.
    My dad's VN had a rubbing noise from the water pump for a while, after a month it sheared the pulley off the destroyed the water pump. Luckily he was at the end of the street and could pull straight over avoiding further damage.
    But yeah, get it looked at if you can't diagnose it yourself.
    VN S2/ Original XRGT
    Jun 2006
    I had the same noise until i changed my tensioner pulley but i have told that it is the spring inside that can make that noise also.But i just had to change the pully .
    VN 5 spd/VR Calais daily driver
    Mar 2006
    NZ
    Check that the tensioner pulley is working inside it's normal operating range. There's two little marks and an arrow.
  1. Whats is the best way to start learning about your car?
    By confucia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2007, 11:06 AM
  2. LS1 computer re-learning question
    By Donnie in forum LSx Development and Modification
    Last Post: 25-11-2006, 01:05 AM
  3. Cops learning to drift
    By jd hot stuff in forum The Pub
    Last Post: 01-08-2006, 09:02 PM
  4. Learning VY's
    By fxcustoms in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-06-2006, 04:20 AM
  5. Learning about cars
    By daveb8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-11-2004, 10:23 PM
