I was just trying to eliminate my struglling idle, and was cleaning my throttle body/IAC. I had the IAC out, cleaned the pintle, but noticed that it moved from side to side a fair bit. Is this normal? What else can I do to fix my idle - symptoms are:
- Only happens when stationary, or slowly rolling
- Usually happens after five minutes of driving - not before
- sometimes revs fluctuate enough to make it sound like its going to stall - ~400RPM
I think it is either the IAC, or possibly oxy? apparently o2 sensor can do this, but not by 400rpm. I also need to check leads, plugs were replaced not too long ago, so I don't think its them...
Its pritty normal, my one does it aswell, it shouldnt move much when its screwed back into the base setting which is like 12mm if i remember correctly![]()
Check the ecu for fault codes. See if there is anything in there...then reset it. That might make all the difference.
Gravity is proof that nature keeps getting us down.
IAC has to be set to a certain size before re-installing it, i got a picture somewhere if that helps Jack.
Illegitimi Non Carborundum
It says it in my book at home, i think its 12mm from memory, ill dig it up when i get home![]()
I thought it was 28mm? Thats what mine was. Anyway, the problem seem sto have gone away for now, so thats good.
From the tip of the little 'hat' on the end of the pintle, to the main body of the IACV needs to be less than 28mm. That's what my Gregory's says anyway.
Make it less than that, and when you reset the computer, it will find the right length.
Probably right lol, might be remembering the wrong thing![]()
