+ Reply to Thread
Results 1 to 17 of 17
Thread: Guide to New Lead Install For VN SS 5.0L
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Question Guide to New Lead Install For VN SS 5.0L
    hey guys i need the firing order for holden 304 5 litre and labeled diagram how the dizzy ie which cylinder is for what on leads.... thanks
    Cheers.
    * RVN 355 *
    Boonz's Avatar
    Boonz is offline the holden mechanic Boonz Maloo Boonz Maloo
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    1,2,7,8,4,5,6 i think.... its written on the manifold anyway so correct me if im wrong
    Attached Thumbnails Attached Thumbnails Guide to New Lead Install For VN SS 5.0L-diagram.jpg
    VP Executive R-spec
    Jan 2005
    Boonz's Avatar
    Jul 2005
    91 VN SS 355
    Feb 2005
    WEST SUBS
    ok new leads are on thanx for the pics and info guys
    I got TOP GUN 8.8mm RED Spiral Core - when i hold 3 k @ idal the car dies and i gota start it up any ideas guys? stall convertor?
    304 5litre FIRING ORDER 1278456
    Cheers.
    * RVN 355 *
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Wink Guide Leads For 5 Litre
    Guide to Installing New Leads for the 5.0 Litre
    Start from the back off the block, do one lead at a time lol Thanks BOONA 15 make sure u line up each lead to the dizzy then the dizzy lead to the coil....
    All Leads should be tight on the plugs and click on and keep leads away from manifold or hot parts of engine...
    8.8mm leads are good for igniting both lean and rich fule mixtures,reducing miss fire that can occur under heavy load... suitable for ECU,msg ignition, rev limited Engines
    TOP GUN - PRO RACING SPIRAL WIRE 8.8mm and 10.0mm
    Double insulated, high temperature cable (250°C plus). Features a reinforced fibreglass braid interwoven between the layers of silicone insulation. The conductor utilises a spirally wound stainless steel construction, in which a single stainless steel wire is helically wound around either a ferrite or kevlar carrier. This conductor has good RFI suppression qualities, with a resistance of between 2,000-2,700Ω per metre length. Uniquely suited for performance applications, for both race track and street applications. (WWW.TOPGUNLEADS.COM.AU)
    Cheers.
    * RVN 355 *
    VP Executive R-spec
    Jan 2005
    And make sure the engine is cooled down because sure enough you are going to have to lay on it to plug some of them in
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Default Dizzy Brands
    For a upgrade consider MSD or Crane Cams
    Crane Cams: Street/Race Distributor
    The ultimate in distributor ignition firing accuracy!
    For street or all-out race
    Accurate to +/- .5 degrees at all RPM levels!
    Magnetic trigger plug works with most Crane Cams Ignitions plus many others
    9 electronically pre-programmed ?mechanical? advance curves3 electronically pre-programmed ?vacuum? advance curves
    Zero position provides advance lock-out for crank trigger ignitionsPhoto-etched, stainless steel trigger disc eliminates flex and corrosion
    Aircraft quality upper bearing for long life, precision alignment
    Adjustable slip collar (GM apps) for machined block heights
    Billet 6061-T6 aluminum housing
    Composite lower housing bearing holds true alignment
    Precision M-A-P sensor built-in
    Solid brass cap terminals ensure maximum current conductivity
    Fully urethane sealed against dirt, oil, and moisture.
    Surface mount robotic assembly for accuracy? same as used in laptops a...
    Cheers.
    * RVN 355 *
    AirStrike's Avatar
    AirStrike is offline Site Administrator AirStrike W427 AirStrike W427 AirStrike W427 AirStrike W427
    2009 G6ET
    Jul 2003
    Anyone know the part or model number for the MSD dizzy to suit a VN 5.0l?
    AirStrike
    91 VN SS 355
    Feb 2005
    WEST SUBS
    not sure i found info about the crane one on there website, but ill find out about the msd one
    Cheers.
    * RVN 355 *
    1998 vt clubsport replica
    Dec 2008
    Perth, NOR
    Quote Originally Posted by greenfoam View Post
    It'll cost you , I'll have a look for it
    Attachment 21212
    i know its an old thread but this came up when i was searching i know what the firing order is, but where does it start on the cap is it before or after the clip?
    Dan355's Avatar
    Dan355 is offline Go THE SS's Dan355 Calais
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    Follow number one cylinder lead to the distributor cap. It starts from number one lead (inclusive) in a clockwise direction. Lead order 1,2,7,8,4,5,6,3
    Dec 2008
    Perth, NOR
    yeh didnt really answer my question but i worked it out, lead one goes after the cap clip..
    thanks anway
    vy
    Mar 2009
    Quote Originally Posted by Peanuts Inc. View Post
    what about the 3????
  15. #15
    Dec 2008
    Perth, NOR
    yeh the firing order is written on the manifold and it is 12784563 but my question was where was one on the dizzy cap, no use following the lead from no.1 spark plug as the car was f**cked around with before i got it, so i replaced everything in the ignition system and was wanting to verify where one started on the dizzy cap, before or after the clip for the cap. i worked out it is after the clip..
  16. #16
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep wrx884 Caprice
    VT Commodore Exec/5L VP Calais
    Mar 2006
    ahh i know wat ya mean i got the same pic from greenfoam a lil while ago 2 do tha same thing. The pic posted and how the dizzy sits was different 2 how mine was sittin in position, so basically where number 1 lead is in the pic i had 2 put the number 3 lead there, or mayb it was number 2 but neways it didnt show the starting point lol.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  17. #17
    immortality's Avatar
    immortality is offline crappy ol' VN driver immortality W427 immortality W427 immortality W427
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Quote Originally Posted by vh_sle_81 View Post
    actually, you could start No:1 anywhere on the cap as long as you follow the correct firing order and obviously line up the rotor to suit. from memoey i started No:1 a litle further around then shown in that drawing andi don't have any of hte leads crossing another around the cap like the No:8 lead does in the above diagram
    Body by Holden, Soul by Brock
    the Legend will live forever
+ Reply to Thread
  1. Complete guide to nokia CK-7W install in VY/VZ.
    By bradwilks80 in forum Electrical Wiring / Questions
    Last Post: 06-04-2010, 06:26 PM
  2. Power lead
    By vs_clubby in forum Car Audio
    Last Post: 01-05-2007, 09:29 AM
  3. Where does this lead??
    By cypher967 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 10:42 PM
  4. has anyone made an amp install guide for vn?
    By beefcream in forum Car Audio
    Last Post: 15-04-2006, 10:20 AM
  5. Subwoofer Sealed Enclosure Install Guide
    By Kersh in forum Car Audio
    Last Post: 22-10-2005, 10:20 PM
