Results 1 to 2 of 2
Thread: VN Series 1 manual to auto
    Tadeusz Guest
    Default VN Series 1 manual to auto
    Hi,
    I've got a series 1 VN v6 motor in a Hilux 4wd. Currently is has a Hilux 5 speed behind it. I don't know the history of the motor since I bought the car with the motor already installed. Anyway, I'm considering converting from the 5 speed to an auto.
    Can I put an auto behind this engine, or would I need an engine that originally had an auto behind it? If I can, what's required? Do I need to change the computer?
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    not telling
    Space Invaders Champion!
    Oct 2002
    ok, quick lesson, about gearbag's on the vn series commies
    the auto in the series one is a good strong gearbox, look after it, it will look after you
    the series1 and series2 motors are 2 different things, i guess the very first thing you need to make sure is that it's a series1, and not a series2
    the series1 gearbox will bolt straight onto the series1 motor, no drama's, but you need to make sure it's a series1 gearbox.
    series1 and series2 bolt onto different spots on the torque conveter, also, you will need to get a torque converter, rid of anything to do with manual all toether, remove pressure plates, clutch stuff like that
    also, you will prob need to run down the wiring for the toruqe conveter clutch solenoid, and the park and neutral switch, all these should be in the wiring loom still, somewhere,
    as for changing ecu's, no need to, just go and get a memcal out of a auto, and slip it straight in, it's as easy as that
    cheers
    garth
    i am the god of britany spears womanizer on just dance on the wii
  1. Do VN Series 2 Auto and manual have the same cranks
    By jonathanvb in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-09-2007, 07:24 PM
  2. Will a VN series 1 manual g/box fit onto VP series 2 motor?
    By VPioneer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2007, 05:27 PM
  3. WTB. Vs series 2-3 manual pedalbox
    By BFCK97 in forum Parts And Other Items For Sale
    Last Post: 26-01-2007, 08:26 PM
  4. series one 3.8 v6 auto to manual ?
    By kiwigem in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-03-2006, 06:50 PM
  5. Commodore Manual VN-VG Series *SA*
    By SlyVR in forum Parts And Other Items For Sale
    Last Post: 30-01-2006, 11:13 AM
