Results 1 to 5 of 5
Thread: Lights in cluster are'nt working HELP!!!!!!
    VN S2/ Original XRGT
    Jun 2006
    Default Lights in cluster are'nt working HELP!!!!!!
    I changed clusters yesterday and the lights in the cluster where all working perfectly last night.But i just noticed now that when i put my headlights on the lights in the cluster dont work at all now i have checked all the fuse's inside the car.Doe's anyone know what could be the problem ? please help cause i gotta drive my car tonight.
    VR Berlina auto s2
    Aug 2005
    the shire!
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    check your fuses and see if they are getting power to both sides (assuming they are good) with a test light.
    Have you checked that the connections on both clusters are the same?
    Have you knocked the dash dimmer switch on?
    Illegitimi Non Carborundum
    anton1o's Avatar
    anton1o is offline [GMHVN6]
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    Ive got the exact same problem haha.
    When i have my car On, the Dash wont show the car lights are on.. Turn car off Lights turn on the dash..
    I havent removed my cluster yet to check whats happening behind it.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    If you havn't worked it out, ensure that the dimmer switch is in properly. I had the same issue. SO thats dimmer switch in properly.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
  1. VR Cluster Lights Not Working
    By themann in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2008, 05:15 AM
  2. level 3 cluster - some lights not working
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-08-2007, 12:02 AM
  3. lights not working
    By bradvt98 in forum Electrical Wiring / Questions
    Last Post: 17-12-2006, 08:43 AM
  4. airflow controller not working - vacuum cluster problem?
    By catalyst55 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2006, 01:18 PM
  5. cluster lights and speed alert not working
    By tgolds1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2006, 07:47 PM
