Results 1 to 11 of 11
Thread: Checking your Flex Plate(Drive Plate)
    VN S2 Berlina Wagon
    Apr 2004
    Default Checking your Flex Plate(Drive Plate)
    I have a vns2 auto and i'm getting a vp tranny (160,000kms) installed in my car tomorrow. mines done about 300,000kms and is starting to play up. anyway I just want to know if you can check the condition of the flex plate without taking the transmission off. This is because I have been suss on it making a noise for a while and I wont have time to purchase a new one while the tranny is being replaced.
    any help?...... cheers
    PaRaDoX's Avatar
    PaRaDoX is online now boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    yep... you can,
    the starter motor has a opening to the flywheel/flexplate/driveplate,
    you can see in and see the health of your tread...
    to do it you need to remove the passengerside headers, spark plugs, jack the side of the car up and use car stands please, its a must... remove air pipe and pretty much just unbolt the starter motor (will have 3 bolts)then unwire it...
    after all that grab a torch and look in on your flywheel...mine has a fair bit of wear on it
    give me a pm if u need more detailed instructions
    VN S2 Berlina Wagon
    Apr 2004
    thanks mate, I might take a chance and hope mine's OK.....im over taking the headers off
    I might have to take the tranny off again though.
    VN S2 Berlina Wagon
    Apr 2004
    I would also like to see where the bolts holes are cause apparently thats where the cracks usually are.
    maginoodle's Avatar
    maginoodle is online now Donating Member
    vy series2 ss crewman
    Apr 2006
    Quote Originally Posted by lazza44
    you can check the ring gear and the bolt surrounds on the torque converter bolts by taking the inspection cover off. put the car on ramps and have a look at the front of the tranny, there is a cover with about 4-6 bolts(from memory its been a while) undo them bolts and take that cover off.
    you wont be able to check the bolts that hold the flex plate to the crank like this cause you wont be able to see them.
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    yeah, to check the bolts on the flex plate you need the transmission out of the car
    VN S2 Berlina Wagon
    Apr 2004
    I put it on ramps but it look like to much of a hassle to take off the inspection cover. U would need to take off the rack and possibly otherthings aswell. cheers guys.
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    VN S2 Berlina Wagon
    Apr 2004
    maginoodle's Avatar
    Apr 2006
    its gotta come off to change the tranny. if you clean the area the mechanic wont have to, so you wont get the extra labour costs. if you got a quote you wont have any extra charges anyway.
    VN S2 Berlina Wagon
    Apr 2004
    Its all done, the flex plate was fine but the tranny mount was missing one bolt and the other was loose!! The starter motor cable (the one going to the battery) was touching metal, very dangerous.
  1. 8 Bolt flywheel/flex plate torque settings?
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-09-2007, 11:23 AM
  2. Tooth count on LS1 flex plate?
    By maddog in forum LSx Development and Modification
    Last Post: 20-11-2006, 10:06 AM
  3. Flex Plate Balance
    By roger05 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-09-2006, 07:31 PM
  4. Flex Plate???
    By weedo_86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2006, 05:28 PM
  5. Wanted 8 bolt hole Auto V6 VN-VP flex plate
    By kowan in forum Swap / Wanted to Buy / Trade
    Last Post: 16-03-2006, 10:05 PM
