Results 1 to 20 of 20
Thread: The next step
    VP WAGON V6
    Mar 2006
    Default The next step
    ok, currently i have 2.5' cat back, 70mm tb, pod, CAI.. you get the gist anyway i got some money landing my may in the next few weeks and im basically setting my car up for the turbos to be bolted on somewhere before chistmas. But where should i go from here. Obviously i dont want extractors cause they are just going to be ripped off. Should i get some yella terra rockers and maybe a bit of a head work or. something else. Im hopefully getting a new auto soon just gotta find a DECENT one in a car still so i can drive it and get it checked by a mechanic and a stage 2 shift kit stuck in. I will be getting some 3.9 diff gears in around a month so thats out as well. So basically ill have about a grand to spend on the engine. Minus a couple of things that i have to buy should be around $250 max but yeah. So any other ideas where to start now???
    p.s. Whats a new sump worth. Prob a larger volume if possible????
    Michael
    p.s. is a vp v6
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    If your gonna turbo it?
    Well.....
    CAM + CHIP
    NEW ROCKERS
    HEAD PORTED, BLUEPRINTED, POLISHED
    NEW INJECTORS, LEADS,
    NEW FUEL RAILS
    NEW SUMP
    FORGED PISTONS
    FORGED CONRODS
    thats just to start with.... if your getting serious about turboing and really forcing air into your engine... thats what i would start with. With only 250... your not looking to hot interms of modding it. I would get the cam package.. but you cant really afford it wiht 250. SAve your money dude.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    May 2005
    .....SE Burbs
    Sorry i re-read the post.... turbo(s)??????
    everything above plus more......
    you said youll have 250 to spend or 250 on other things....???
    ok, well asume you have $700....
    new cam + chip package... or the roller rockers.
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
    VP WAGON V6
    Mar 2006
    yeah mate ill have between 700 and 800 to spend i think. lol. Basically i have to buy my dvd screen and power supply for my car pc. But ill be getting the power supply next fortnight hopefully. Well thats if work is nice to me.
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    copper head gasket ringed as well(forgot the proper name ) why forged rods? i would have thought unless you are gonna put a huge cam in there and reve it heaps then you wouldnt need them.
    VN Commodore
    Feb 2006
    lot of people on the forum have said time and time again that a v6 will handle 8 or 10 psi no worries. which it should. there is one fella who is getting 220rwkw's with a stock motor
    VP WAGON V6
    Mar 2006
    yeah i no this. They should handle around 240 without to many mods. But i want it to be sota reliable. I dont want it off the road every second week cause i keep breaking things. Ill only be running 8psi on the stocko motor.. But as time and money persisits i want to build another motor to take alot more. Something that will scare the absolute SHIAT out of me infact. Basically with the stock motor and running 3.9 diff gears i want to be well in the 13s. I think this is very possible even though ill be running simple manifolds.
    Ive been thinking about it all day and i think im going to get a set of rockers, and any money left over ill chuck either towards my gb or getting 36lb injectors to sit in my cuboard until i get the manifolds and turbos and stuff.
    So that leaves me with my next question... What ratio rockers would suit?????
    AdamIan69 Guest
    VN Commodore
    Feb 2006
    i bought some 24lb injectors from the us for $50 au delivered. that is the best place to look for that sort of thing. i even beat him down a little on his buy it now price..
    there was a turbo kit on ebay yesterday.. i don't think it lasted 24 hours, as it is sold already.. would be fairly good. was a single t04 with wastegate. was for 1000. it came with a chip and all. it looked like the bloke crashed his car and was just selling bits off..
    fu2's Avatar
    fu2
    fu2 is offline The Man With No Name
    VP Berlina II - MY10 VE SV6 Ute - VH SL/E
    Jul 2004
    by memory the vs ecotec sumps are bigger and they hold more. i could be wrong but i heard they are ok.
    VP WAGON V6
    Mar 2006
    fu2's Avatar
    fu2
    Jul 2004
    suposedly, by memory sc tryed it with vengence but being the s1 engine they couldnt get the dipstick to work
    VP WAGON V6
    Mar 2006
    ok cool i might head over to sc when im finished here and see what i can find. Anyidea how much bigger the vs sump is??
    fu2's Avatar
    fu2
    Jul 2004
    nah not 2 sure on that one mate. they are ment to be lighter though (made out of a different material)
    see what sc says, im sure some vengance follower would be able to give u a bit more info
  15. #15
    Vp Commodore
    Dec 2005
    umm not sure if you will need to, but wouldnt a new fuel pump be on the top of the list? like a bosch 044 or something, depending on the amount of power your going for
  16. #16
    VP Executive R-spec
    Jan 2005
    injectors and a 2 bar map sensor and an eprom burner (all must buy items for you) and maybe some money in the bank incase you need a stronger pair of head gaskets later on, don't worry about the rest of the engine unless it breaks, doubt you will break it on 8psi anyway. The rods and pistons seem to be fatter and stronger than the super 6's. Fuel pump should be OK a quick run on the dyno will tell you later on anyways
  17. #17
    PaRaDoX's Avatar
    PaRaDoX is online now boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    what are the turbo headers worth for a vn???
    was reading the v6 vengence article, he listed them as $1200 but surely they can be obtained for cheaper???
  18. #18
    VP WAGON V6
    Mar 2006
    well i sat there for like 15 minuts the other day trying to work it out. What i have come up with is a single turbo, running on the passenger side of the car. Using stock headers on the drivers side and a custom one of the passenger side. That way i can sorta limit the use of steam pipe and cut the cost down that extra bit. Will run a cross over pipe along the back of the engine to bring it accross. Then i will need to maybe make a custim plenum with the tb on the drivers side. This will make it so much easier to get the boost from the cooler. 3 inch dump pipe down to the high flow cat running my 2.5 inch zorst.. That was it saves a bit of dosh dosh... Ive been told it should be a pritty good setup.. just need a rising rate fuel reg some bigger injectors and the manifold as well as the turbo and dump pipe and it should all be good SHOULD I SAY...
    p.s if this is hard to read i am sorry... but ive been down the pub since 6 and QLD WON!!!!! QLDER!!!!!! im not drunk
  19. #19
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    not a bad idea, let me know when you get prices on a single turbo manifold as im intrested, i suppose if you wanted to later you could always add another turbo on the other 3 cyclinders
  20. #20
    VP WAGON V6
    Mar 2006
    well im going to TRY and make the manifolds myself. cause i wanna do as much as possible myself. I just read that post i wrote the other night.. was pritty good considering i dont remember doing it.. like i said i wasnt drunk. but anyway that is the basic setup i wanna do.. There is alot more involved then what i said though.. oil lines, cooler, cooler pipe etc etc etc.. im not sure wether or not to get another engine or use this one. Cause this ones got 265000 on it and i think it might be getting a bit tired. I dont wanna do any internal work to this one i think..
  1. RB30 Engine Troubleshooting/Maintenance Step by step
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-07-2010, 05:23 PM
  2. step by step manifold making
    By hinterland in forum V6 Development And Modification
    Last Post: 28-05-2008, 12:19 PM
  3. injector cleaning step by step???
    By hold-on in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-09-2006, 05:40 PM
  4. Fixin da front of my vl step by step *pics*
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-03-2006, 05:43 PM
  5. The next step...
    By jack.mc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-07-2005, 01:36 PM
