A mate of mine has asked me to fix his Series 1 6-pot VN.
He says it's missing at low revs, he thinks it's missing on cylinder 5. He replaced leads, plugs, cleaned the TB, changed the oil.
I'm thinking it's coil-pack (it's the old S1 style) or the DFI module.
Is it possible to pull off my VS coil-pack and put it on the VN for testing purposes? Or is there a better way to test the coil-pack and DFI module?
In the case it's not the coil or DFI, what else could it be?
My Vn does the same thing, i noticed it gets worse the hotter the engine gets until you can hardly accelerate in 5th gear. i have changed my leads, plugs, coils, DFI module, and MAP sensor. i took my VN for a drive tonight waited till it got to full operating temperature, and then pored 2 litres of water of the Crank Angle Sensor, to cool it down. it didnt completly stop the miss, but helped it considerably. give it a go and tell me how you went!
I would strongly think its the Coil Pack..
ride; [GMHVN6] Project Streeter - VN Berlina '90 mods; 65mm throttle-body / Cold Air Intake / 8mm Ignition Leads / Exhaust
future; Extractors , Cam currently; 101.2rwkw mission; 110rwkw
I have replaced them with S2 coil packs and dfi module, didnt work? Anything else it could be.
Didn't test the coil-pack.
Did a compression test and cylinder 3 had 50psi dry and 80psi wet. Every other cylinder has a very even 125psi.
I'm thinking bent-valve, stuck valve seat or broken piston ring.![]()
