Can anyone tell me if Monroe Front Gas Struts from a VL Calais will fit a VN Wagon?
Thx
Chris![]()
Yeah they will man...
There is a difference between wagon and sedan but thats only for the rear. Front is exactly the same.
It should be the following part:
GT Gas w/- Reflex Cartridge.........Part number is 25-3632+
Thanks![]()
mmm not 2 sure but like 1991_vn2nv said back is different in a sedan and wagon but front should be the same
Check Out My Ride Here: 91 VN Calais[/CENTER]
They are definitely the same on the front. Sedan and wagon, VL and VN, standard height and lowered, its all the same for the front.
front use the same coil over struts, the rear suspension is diffrent, they also have to be siffer or something.... (springs and shocks are diffrent, extra weight carring)
hi, guys where can I get some second hand shock and spring front for vn.
Wreckers...where abouts in aus u from? If ur from SA i can name some decent places to go
hi, I am in sydney.
Ah ok...well just any decent wreckers...Try the NSW Chapter section and see if they have a thread on good wreckers. If not, start a thread asking what wreckers would be best in your area.
thanks mate, I will go to botany again. got a set of 4 calais 15 alloy with rubber for 230. do not know if this is alright.
