Results 1 to 18 of 18
Thread: VP central locking..
    1995 VRII V6 Executive 5 speed
    Sep 2005
    Default VP central locking..
    Hey guys,
    Having a small drama with my central locking -
    I hit the remote and both front driver side and passenger doors lock but not the two back doors. Though when all doors are locked and i hit the remote they all open? so it seems that when im locking it there is a problem, i can see the back doors trying to lock but they dont move enough to engage.
    Also my VP manual does not have a tacho on the dash, can i upgrade to a tacho dash with a neat swap?
    Thanks alot
    anton1o's Avatar
    anton1o is offline [GMHVN6]
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    The Cluster swap is easy, just head down to your local wreckers and pick up a lvl 2 from any VP.. Undo a few screws pull the old out.. Put new in.. Start er up
    For the Central-Locking.. It sounds like your remote Button is broken?
    ride; [GMHVN6] Project Streeter - VN Berlina '90 mods; 65mm throttle-body / Cold Air Intake / 8mm Ignition Leads / Exhaust
    future; Extractors , Cam currently; 101.2rwkw mission; 110rwkw
    Sep 2005
    Thanks, but are the lvl 2 dashes pre-wired to handle a car with a factory lvl 1 dash, if that makes sense. Basically scince my car came out of factory with a lvl 1 dash with no tacho, does changing to lvl 2 require the tacho wire to be hooked up or is it already there?
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    a level 2 cluster from a vp will fit and work with no mods or changes in a factory level 1 vp.
    as for the remote, it sounds like either the locking mechanism is tight and the actuators are having trouble locking, or theyre on their way out and unlocking is easier for it. will mean having to rip the door trims off the back, id suggest getting a couple of rear actuators from the wreckers first, then take trims off one day, see if its just tight somewhere, if not, swap the actuators over and test, see if it fixes it.
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Quote Originally Posted by mitchyp
    Hey guys,
    Thanks alot
    I have had pretty much the same problem with myn, Drivers door wouldn't open or lock, Back passenger door wouldn't lock but would open.
    I replaced both motors on the back door and drivers door,
    But the problem with the back door was simply fix fixed with a little WD40 and open and closing it about 40 times, It had seemed over the years dust and crap built up and it was so stiff only the 45deg heat in summer would make it work right.
    Give them a little spray at the arms in the back of the door and see if that works.
    My doors to lock them i had to press the remote button and then press the drivers door lock, But i had to lean over and lock the back door by hand.
    Now they all open and close for me thank god.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    Sep 2005
    Thanks for the help guys, i think i will give good ol WD40 a try first.. then go from there
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    My central locking doesn't work full stop. Everything is there, plugged it, yet no voltage from the fuse box. Fuse is ok. I was thinking maybe a dead module?
    Life's Grouse in Frankston South!
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Does it work lock all doors if you press it by hand??
    fazz1977's Avatar
    Aug 2005
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Now that does sound bad very strange. Maybe a auto elec could have a look and tell u maybe?
    fazz1977's Avatar
    Aug 2005
    That's what I was thinking. I tested back as far as the fuse box, no voltage at the central locking fuse terminal. Fuse OK.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Might be the fuse box itself?
    fazz1977's Avatar
    Aug 2005
    Could be. Hassle. Everything else works a treat except that one thing.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Theres nothing worse then having to check and reach over and lock other doors before leaving the car, I spent a day on my doors and didn't realise till 2 days later it was all working OK, I still got the scars on my hands it's a bitch of a place to stick the motors.
    Hope you get them working soon.
  15. #15
    fazz1977's Avatar
    Aug 2005
    Thanks mate. I might leave it to the auto elecs.
  16. #16
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    It's just a shame they charge so much, But maybe they can find the problem first without charging you and then give you the total price, Then maybe it might be fixable for you to do it and save a mint
    MitchVP Any good with the WD40???
  17. #17
    Sep 2005
    Hey guys,
    GREEN LIGHT for the WD40 for me, it worked like a charm, the locks were just a little clogged up.
  18. #18
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Thought that would work over the years god knows what builds up in there, It only takes a little stiffness to stop it going down, Up is easy
  1. central locking
    By brooksy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2011, 09:41 AM
  2. central locking?
    By jet_pilot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2007, 10:49 PM
  3. central locking
    By stewart in forum Electrical Wiring / Questions
    Last Post: 30-10-2005, 02:23 PM
  4. Central Locking
    By Tekka in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-07-2005, 02:18 PM
  5. Central Locking
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2005, 07:27 PM
