Results 1 to 6 of 6
Thread: where can i buy diff pinion shims??
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    Default where can i buy diff pinion shims??
    i was wondering if anyone knows where i can buy pinion depth shims for my bw m78 live axle diff im in SA but am willing to purchase interstate or even oversees if i have to
    im not admiring your car im looking in disgust
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Pinion shims?? What are you trying to do?
    AirStrike
    Selling FG G6E Turbo and buying a N/A Supra
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    91 VN SS 355
    Feb 2005
    WEST SUBS
    VP WAGON V6
    Mar 2006
    what exactly are the shims. I have a spare diff sitting here i can strip down a bit. I also have all the spider gears sitting here out of my vp
    manual VN aero
    May 2005
    SA
    ok i am changing the gears and doing so im replacing the bearings and bearing cups now the pinion depth shim is located behind the lower bearing cup and as a result of removing this cup from the housing the shim has been damaged so i need a replacement
    so no im not adding a shim lmfao
    and it would be highly unlikely to be able to remove a shim without damaging it but thanks anyway commy92
    thanks for the suggestion subdue hopefully they can help me out i just tried calling them but i got an answering machine
  1. 4 Pinion Lsd 28 Spline Aka "vl Turbo" / V8 Diff Center
    By Void in forum Parts And Other Items For Sale
    Last Post: 14-06-2008, 10:18 AM
  2. Rear Axle Shims ?
    By Rossco in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-09-2007, 08:07 PM
  3. Need diff crown & Pinion pair VB 3.08 Ratio
    By rjdd in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-08-2006, 09:27 PM
  4. bxh 136 bosch mini starter shims
    By FCCOOL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-12-2005, 09:52 AM
