Results 1 to 4 of 4
Thread: help locks jammed
    vs executive s2
    Jun 2005
    Default help locks jammed
    hi i started to take myengine out and had to stop the 2 days later i went back to the car and i can only open the drivers side door the others are jammed on does someone no how to get them open or what i have done for this to happen
    cheers
    VN 5 spd/VR Calais daily driver
    Mar 2006
    NZ
    Yea this happened to me too. I could only work the drivers lock and the rest were stuck in their position. The central locking was fixing itself in place because I had the battery out (it doesn't usually happen when I take the battery out though). Try putting a battery back in the car and see if you can play with the central locking to get them all going.
    vs executive s2
    Jun 2005
    yeah this is the third time i have had the battery out and this is the first time this has happen and i plugged all the battery back up and still no luck so i will have to wait to the engine is finished
    VP WAGON V6
    Mar 2006
    did you try to unlock it with the key??
  1. stirk still jammed
    By uncle stirk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-11-2007, 03:22 PM
  2. Jammed Glovebox
    By Mav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2006, 10:45 AM
  3. Jammed Rear door
    By IhateRICE! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2006, 04:48 PM
  4. jammed door lock
    By ray moyle in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-10-2005, 03:33 AM
  5. vx stacker jammed
    By lilkel in forum Car Audio
    Last Post: 05-05-2005, 09:14 PM
